电子发烧友论坛|
你好,
我正在尝试我的旧Flash库。(对于SPC560B50L5)但是没有用。如何在SPC564B70L7上使用DFLASH? (debug stop =>''_ unhandled_exception:'') 非常感谢。 #dflash 以上来自于谷歌翻译 以下为原文 Hello, I'm trying my old Flash Library.(for SPC560B50L5) But not working. How is use DFLASH for SPC564B70L7? (debug stop => ''_unhandled_exception:'') Thanks a lot. #dflash |
5个回答
你好Orhan,
BCxx系列(B50L5)和ECxx系列(B70L7)之间的Flash地图不同 检查SPC5Studio中的以下示例。 SPC56ECxx无操作系统闪存测试应用程序 SPC560BCxx无操作系统闪存测试应用程序 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Orhan , the Flash map is different between BCxx Family (B50L5) and ECxx family (B70L7) Check the following examples in SPC5Studio. SPC56ECxx OS-Less Flash Test Application SPC560BCxx OS-Less Flash Test Application Best regards Erwan |
你好Orhan,
在FLASH DRIVER SPC5Studio组件上,我们没有Flash驱动程序源代码。 你在DFLASH上试过Giovanni的代码吗? [DEAD LINK /public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/SPC56/Using%20Data%20flash&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058¤tviews=306]https://my .st.com /公共/ STe2ecommunities / MCU /列表/ SPC56 / Flat.aspx RootFolder =%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSPC56%2FUsing%20Data%20flash&安培; FolderCTID = 0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058&安培; currentviews = 306 2015年的老帖子。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Orhan , on FLASH DRIVER SPC5Studio component, We have not the flash driver source code. Did you try Giovanni's code on DFLASH ? [DEAD LINK /public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/SPC56/Using%20Data%20flash&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058¤tviews=306]https://my.st.com/public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSPC56%2FUsing%20Data%20flash&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058¤tviews=306 old post in 2015. Best regards Erwan |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1447 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1494 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3641 浏览 1 评论
3834 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2454 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 19:06 , Processed in 1.202617 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1344
