电子发烧友论坛|
亲爱的大家,
我正在研究LIS3DH并尝试正确开发嵌入式自测功能。 我所做的只是评估“正常测量”和“自测量测量”之间的差异,并检查这些差异是否与数据表第10页中声明的自测输出变化相匹配。 问题是(@ 3V电源)我总是得到大约数据表中指示值的一半的值。 我还在网上找到了这个自我测试程序: http://www.edn.com/design/analog ... MS-inertial-sensors 并且它强调测量的差异应介于两者之间,但我无法在数据表中找到SELF TEST OUTPUT CHANGE的MIN / MAX值。 考虑到它还取决于电源,我如何评估我的应用工作在3.6V和2.5V之间的MIN / MAX值? 等你回复, 最好的祝福, 克劳迪奥 #lis3dh自检 以上来自于谷歌翻译 以下为原文 Dear all, I am working on the LIS3DH and trying to correctly develop the embedded Self Test feature. All I do is evaluating the difference between the ''Normal Measurements'' and the ''Self Test Measurements'' and check if these differences match with the Self Test Output Change declared at page 10 in the Data Sheet. The problem is that (@3V supply) I always get values about one half the ones indicated in the data sheet. I also found this Self Test Procedure on the web: http://www.edn.com/design/analog ... MS-inertial-sensors and it underlines that the measured difference should fall between but I cannot find on the Data Sheet the MIN/MAX values for the SELF TEST OUTPUT CHANGE. Considering that it also depends on the power supply, how can I evaluate this MIN/MAX value for my application working between 3.6V and 2.5V?? Waiting for you reply, Best regards, Claudio #lis3dh-self-test |
2个回答
你好Claudio,
LIS3DH加速度计自检最小/最大值为:min_x = min_y = min_z = 60mg,max_x = max_y = max_z = 1700mg。在+/- 2g FS时,这意味着最小值为60LSBs,最大值为1700LSB,因为灵敏度为1mg / LSB。 该最小/最大范围涵盖1.71V至3.6V的所有Vdd,所有FS范围和所有ODR。如果这是您正在寻找的信息,请告诉我。 谢谢, 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello Claudio, LIS3DH accelerometer self-test min/max values are: min_x = min_y = min_z = 60mg and max_x = max_y = max_z = 1700mg. At +/-2g FS, this translates to 60LSBs min and 1700LSBs max values because the sensitivity is 1mg/LSB. This min/max range covers all Vdd from 1.71V to 3.6V, all FS ranges and all ODRs. Please let me know if this was the information that you were looking for. Thank you, Thiago Reis |
你好Thiago,
我不明白你的答案=>在数据表中,X和Y写入276 LSb,Z轴写入984 LSb。你如何证明你的答案? 最好的祝福。密歇根州。 以上来自于谷歌翻译 以下为原文 Hello Thiago, I do not understand your answer => in the datasheet it is written 276 LSb for X and Y, and 984 LSb for Z axis. How do you justify your answer? Best Regards. Mich. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 06:37 , Processed in 2.064683 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1481
