你好,柏树论坛的女士们和先生们,我再次来向你们乞求一片你们的天才。
长话短说,我需要能够使用相同的8个引脚来处理各种类型的输入(我使用的是模块化外部硬件)。在一种情况下,用户可以将按钮或旋转编码器放置在输入上,并且在另一种情况下,用户可以将电位计放置在同一销上。 我想要的是一种使用PIN作为模拟和数字之间切换的方法,同时理想地将所有引脚保持在同一端口上。棘手的部分是,我需要有状态转换中断触发那些引脚设置为数字,以便我可以使用旋转编码器在设计中(另一条腿连接到一个引脚上的端口,将永远是数字)。 这甚至可能在049个套件上吗?我将不得不咬紧牙关,用我宝贵的剩余端口单独处理这两条线(以我为系统计划的其他功能为代价)。 以上来自于百度翻译 以下为原文 Hello Ladies and Gents of the Cypress forums, I have come once again to beg you all for a slice of your genius. Long story short I need to be able to use the same 8 pins to deal with various types of inputs (I'm using modular external hardware). I.E; in one case the user may place a button or rotary encoder across the input, and in another case the user may place a potentiometer across the same pin. What I want is a way to switch between using a pin as analogue and digital , whilst ideally keeping all of the pins on the same port. The tricky part is that I need to have state transition interrupts triggered for those pins which are set to digital so that I may use rotary encoders in the design (the other leg is connected to a pin on a port which will always be digital.) Is this even possible on the 049 kit? WIll I just have to bite the bullet and use my precious remaining port to handle these two lines separately (at the cost of other functionality I had planned for the system.) |
3个回答
嗨,杰米,
在模拟和数字之间切换一个引脚是可能的。下面的一个可能是一个很好的参考你。第6.40章介绍了如何在模拟和数字中重用PIN。 AN864—PSOC 4——使用GPIO引脚CyPress半导体 当做, 欧文 以上来自于百度翻译 以下为原文 Hi Jamie, It is possible to switch a pin between analog and digital. The following AN may be a good reference for you. It introduces how to reuse the pin both for analog and digital in chapter 6.40. AN86439 - PSoC 4 - Using GPIO Pins | Cypress Semiconductor Regards, Owen |
surezc 发表于 2018-11-5 10:21 这是否意味着我可以在同一个端口上使用数字中断,因为没有模拟改变触发中断的情况下发生模拟读取? 以上来自于百度翻译 以下为原文 Does this mean I can use digital interrupts on the same port as I have analogue reads happening without the analogue changes triggering the interrupt? |
你使用同一个PIN作为模拟输入和数字中断吗?如果你这样做,你将需要切换PIN到数字第一,然后你可以使用数字中断。 以上来自于百度翻译 以下为原文 Do you use the same pin as an analogue input and digital interrupt? If you are doing so, you will need to switch the pin to digital first, then you can use digital interrupt. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2098 浏览 1 评论
1845 浏览 1 评论
3664 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1782 浏览 6 评论
1532 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
556浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
410浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
433浏览 2评论
379浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
905浏览 2评论
GMT+8, 2024-12-18 16:22 , Processed in 1.081511 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
