电子发烧友论坛|
你好!我买了一个ICD 4几个月前,因为我炒我的ICD3工作得很好。自从我开始使用ICD4以来,我调试了很多问题。1)它经常在没有警告的情况下重新启动。2)如果在启动调试设置时设置了超过3个断点,那么MPLABX挂在“设置项目断点”3上。调试工具已经出现。该工具将尝试暂时恢复。“调试时,我得到很多。我记得在使用ICD3时遇到了一些问题,但在任何地方我都能看到ICD4所看到的问题。为什么会这样?有没有办法升级ICD4固件,这会有帮助吗?我不能继续这样工作……(我使用MPLABX V4.05,XC8 V 1.34编程PIC18F70J11和PIC18F26K20,我已经尝试了由USB供电的ICD4,由电源供电)/比约恩
以上来自于百度翻译 以下为原文 Hello! I bought an ICD 4 a couple of moths ago since I fried my ICD3 that was working well. Since I started using the ICD4 I have a lot of problems debugging. 1)every now and then it restarts without warning. 2) If I have more than 3 breakpoints set when initiating a debug settings then MplabX hangs on "setting project breakpoints" 3) I get the following message "A communication error with the debug tool has occurred. The tool will attempt to recover momentarily." while debugging, and I get it a lot. I remember having a few problems when I was using the ICD3 but anywhere close to the amount of problems that I see with the ICD4. Why is this? Are there any way to upgrade the ICD4 firmwars, and would that help? I can't go on working like this.. (I'm using MplabX v4.05, XC8 v 1.34 programming PIC18F87J11 and PIC18F26K20 and I have tried the ICD4 powered by USB and powered by a power supply) //Bjorn |
5个回答
尝试MPLABX V4.10,您可能能够得到您的ICD3修复。
以上来自于百度翻译 以下为原文 Try MPLabX V4.10 You might be able to get your icd3 repaired. |
我从来没有想过这样的选择,但我认为我需要一个全新的PCB(基本上是整个产品)。我把它插进我的USB集线器,我用19V来代替5V(坏错误)。印制电路板油炸,并有一个大的黑色烧伤痕迹。既然我的ICD3和垃圾一起出去了,现在就要迟到了。
以上来自于百度翻译 以下为原文 I never thought about that option, but I think that I would have needed a brand new PCB (which basically is the whole product). I plugged it into my USB hub which I supplied with 19V instead of 5V (bad mistake). The PCB got fried and had a big black burn mark on it.. Now it's to late anyway since my ICD3 went out with the trash :( |
尝试它的最新版本。这是一个新产品,并更新更多。还要注意的是,有一个ICD4特定论坛和一个电子邮件地址。
以上来自于百度翻译 以下为原文 Try it with the latest version. It is a new product and is updated more. Also note there is an icd4 specific forum, and an email address. |
好吧,也许我应该试着移动这个帖子……你知道如何更新固件吗?我在MpLabX的ICD4设置中购买了“使用最新固件”
以上来自于百度翻译 以下为原文 ok, Maybe I should try and move this post then.. Do you know how to update the firmware? I have ticket the box "use latest firmware" in the ICD4 settings in MpLabX |
你不能移动一根柱子。你可以在那里挂上一个链接。但你的抱怨是VuGAe…有些是关于MPLABX的普通抱怨,然后使用V4.05兼容固件。ICD固件必须匹配MPLAbX。你需要移动到V4.10。你的问题可能已经解决了。
以上来自于百度翻译 以下为原文 You can't Move a Post. You can put a link there. But you complaints are vugae.. Some is normal complainants about MPlabX. Then you are using the V4.05 compatible firmware. The ICD firmware must match MPLAbX. You need to move to V4.10. Your issues maybe fixed already. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 06:12 , Processed in 0.791274 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5070
