电子发烧友论坛|
在前一个MPLA8XX中,如果我停止调试,我可以重新启动调试而不重新编译所有代码并重新编程。MPLAB X IDE上有可能吗?
以上来自于百度翻译 以下为原文 In the previous MPLAB 8.xx if I stop the debug I can restart the debug without recompile all the code and reprogram again. Is it that possible on MPLAB X IDE? |
8个回答
是的,你可以:)在“调试”符号旁边有一个小箭头。当您单击它时,您可以选择在不重新编译.PIC2620的情况下开始调试。
以上来自于百度翻译 以下为原文 yes you can :) There is a samll arrow next to the "Debug" symbol. When you click on it, you can select to start debug without recompile. pic2620 |
我现在不在我的电脑上,但我想是这样的。只有当源代码没有改变时,它才工作。否则,会得到奇怪的调试结果,比如在错误位置停止断点。PICY2620
以上来自于百度翻译 以下为原文 I´m not at my PC at the moment, but yes, I guess it is called that. It works only, if the source code is not changed. Otherwise, you get strange debug results, like breakpoints stopping at wrong locations. picy2620 |
不工作。当尝试重新启动调试时出错,无法连接并启动调试过程。
以上来自于百度翻译 以下为原文 Did not work. I get an error when tries to restart the debug, something about can't connect and initiate the debug procedure. |
您可以重新启动,而不是通过按下蓝色圆形按钮与两个箭头上的工具栏,它重置固件,其次是圆形绿色“go”按钮。
以上来自于百度翻译 以下为原文 You can restart without recompiling by pressing the blue circular button with the two arrows on the toolbar, which resets the firmware, followed by the circular green "Go" button. |
您能显示在尝试调试会话时获得的错误的屏幕截图吗?我总是使用附件中显示的函数:(对我来说效果很好)
以上来自于百度翻译 以下为原文 Can you show a screenshot of the errors you get when trying to continue a debug session? I always use the function shown in the attachment: (which works fine for me) Attached Image(s) |
嗨,在附图;1。在调试模式2中编译和编程设备。退出调试模式完全完成。暂停程序执行。将程序重置到开始向量5。从程序计数器的任何地方开始程序执行(即开始或断点或暂停的地方)
以上来自于百度翻译 以下为原文 Hi, In the attached picture; 1. Compiles and programs the device in debug mode 2. Exits debug mode completely 3. Pauses the program execution 4. Resets the program to the start vector 5. Starts program execution from wherever the program counter is (i.e Start or a break point or where it was paused) Attached Image(s) |
嗨,在开发帮助网站上有很多关于MPLAX的函数的优秀教程:
以上来自于百度翻译 以下为原文 Hi, There are excellent tutorials on most functions from MPLAB X in the developerhelp website : http://www.microchipdeveloper.com Regards |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 03:55 , Processed in 0.828968 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1152
