电子发烧友论坛|
我曾经尝试过加速度计来找到位置,使用积分法。像往常一样,无法达到精度。然后在MM7150中搜索并最终看到希望。由于它采用了融合算法,所以,思维精度会更好。昨天,当在Explorer 16/32上尝试P24FJ128GA010(V1.40)的示例程序时,它工作并读取MM7150的数据。但要获得这个职位,我仍然需要整合,我说的对吗?哪种模式会更好(加速度计?)也用于校准,看不到它是工作的,它只是说按S4。在1米范围内寻找精度在50米的运动范围内的装置。这是可以实现的吗?
以上来自于百度翻译 以下为原文 Hi In past I have tried the accelerometer to find the position, using the integration method. As usual, was not able to achieve the precision. Then searched and finally saw hope in MM7150. As it uses the Fusion Algorithm, so, thinking the precision will be better. Yesterday, when tried the sample program of P24FJ128GA010 (v1.40) on Explorer 16/32 it works and read the data of MM7150. But to get the position, I still need to do the integration, am I right? And which mode will be better (ACCELEROMETER?)? Also for calibration, do not see it to be working, it just says press S4. Looking for precision of within 1 meter in the range of 50 meter movement of device. Is it achievable? |
1个回答
今天已经用MM7150进行了测量位置的实验。仍然远远超出了准确的预期结果,但得到了MM7150的哪种模式给出了更好的结果的答案。MM7150演示代码有(A)加速度计陀螺仪(B)加速度计。实验观察表明,(a)效果较好,见附图,左侧为(a)和(b),示出位置横过水平轴。在实验中总是把装置移向一个方向,但它仍然显示相反的位置。找到职位刚刚做了双重整合。虽然不是最好的方法,但是(A)看起来比(B)好。也许这就是聚变传感器应该做的,接下来会找到实现精度的方法。如果你们中的任何人有意见或建议,Kalman滤波器将是我想做的实验。
以上来自于百度翻译 以下为原文 Today have done the experiment of measuring position using MM7150. Still as far from accurate expected result, but got answer to the question that which mode of MM7150 gives better result. The MM7150 demo code has (A) Accelerometer Gyrometer (B) Accelerometer. Experiment observation is that the (A) gives better result. See the attached image. The left side is (A) and (B) shows that position is crossing the horizontal axis. in the experiment always moved the device in one direction, still it shows opposite positions. To find the positions have just done the double integration. though it is not the best way but (A) looks better than (B). probably this is what fusion sensor was supposed to do. Next will be finding ways to achieve accuracy. if anyone of you have ideas or suggestion kindly suggest. Kalman Filter will be what I think to experiment with. Attached Image(s) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:29 , Processed in 0.493751 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1636
