电子发烧友论坛|
大家好!
我正在研究一个原型,它将涉及一个ARDUNO和8个PSoC 4设备(CY8KIT-04942XX)通过I2C进行通信。 PSoC将运行相同的软件(唯一的区别是I2C地址,我打算让它在基于分压器的PD上启动)计算,而ARDUNO将运行完全不同的代码。 理想的是,我希望能够通过一个USB连接将未来的软件更新(发布后)推到ARDUNO和所有PSoC上,但我意识到这可能是非常困难的,并且只需要能够将PSoC更新到一起,这样它就不会那么沮丧了。供用户使用。 有人能给我一些建议吗?或者给我指出我应该阅读的方向来学习如何做到这一点。 多谢, 千兆氧肟 以上来自于百度翻译 以下为原文 Hi folks! I am working on a prototype which will involve having one arduino and 8 PSOC 4 devices (the cy8kit-049-42XX)'s communicating over I2C The PSOC's will be running identical software (The only difference is the I2C Address which I intend to have it calculate at startup based on the PD across a voltage divider), and the arduino will be running entirely different code. Ideally I would like to be able to push future software updates (post release) to the arduino and all of the PSOCs over a single USB connection but I realise that this is likely to be incredibly difficult, and would settle for just being able to update the PSOCs together, so that it is less frustrating for the user. Could anyone give me any advice here or point me in the direction of what I should be reading to learn how to do this? Many thanks in advance, Giga xoxoxo |
2个回答
我还应该补充说,由于PSOC4的路由限制,如果潜在的除法器方法不能工作,我可能需要能够上传不同版本的代码。
以上来自于百度翻译 以下为原文 I should also add that I may need to be able to upload different versions of the code should the potential divider method not work due to the routing limitations of the PSOC4 |
嗨,杰米, 你可以尝试拉下所有PSoC芯片的XRE引脚,然后释放并编程1到1。我以前没做过。只是一个想法… 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi Jamie, You can have a try with pulling down XRES pins of All PSoC chips and then release and program 1 by 1. I haven't done it before. Just an idea... Thanks, Ryan |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7241 浏览 0 评论
2482 浏览 1 评论
2175 浏览 1 评论
4037 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2082 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7724浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6280浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
750浏览 2评论
725浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8119浏览 2评论
/9
GMT+8, 2025-12-8 09:48 , Processed in 0.740893 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3050
