电子发烧友论坛|
嗨,所有读过这个主题的人。
我对英语不太好,请原谅我。 所以。 问题:我使用“N5230A PNA-L网络分析仪4端口”有一个问题,我需要使用GPIB命令从Hz移动到dB。 手动,这是通过“扫描 - >扫描类型”来完成的......帮助新手,或者选择讨论这个问题的主题。 (如果我真的找不到它,那么我很自豪地接受了我脸上的西红柿)。 也许某人有一个完整的GPIB命令列表到分析仪? 如果你分享,我将不胜感激 - 我还没找到:(谢谢! 以上来自于谷歌翻译 以下为原文 Hi to everyone who reads this topic. I'm not good with English, forgive me. So. question: I work with "N5230A PNA-L Network Analyzer 4-port" There is a problem, I need to move from Hz to dB using GPIB commands. Manually, this is done through the "Sweep-> Sweep type " ... Help a newbie, or select a topic where this was discussed. (if I really could not find it, then I am proud to accept tomatoes in my face). And maybe someone has a full list of GPIB commands to the analyzer? I would be grateful if you share - I have not found it :( Thank you! |
1个回答
以下是包含N5230A帮助文件的网页:http://na.support.keysight.com/pna/help/index.html您可以根据分析仪上安装的固件版本参考其中一个。
我相信您希望命令选择电源扫描。 以下是命令:http://na.support.keysight.com/pna/help/WebHelp7_5/Programming/GP-IB_Command_Finder/Sense/Sweep_SCPI.htm#ssty PNAHelp中没有完整的命令列表。 但是,从编程指南中,有两种方法可以查找命令。 1.使用看起来像UI的“查找器”。 2.命令树。 您也可以单击对话框上的帮助按钮。 从帮助主题中,找到编程图标。 以上来自于谷歌翻译 以下为原文 Here is the webpage that contains the help file for your N5230A: http://na.support.keysight.com/pna/help/index.html You can reference one of these depending on the firmware revision that is installed on your analyzer. I believe you want the command to select power sweep. Here is the command: http://na.support.keysight.com/pna/help/WebHelp7_5/Programming/GP-IB_Command_Finder/Sense/Sweep_SCPI.htm#ssty There is no comprehensive list of commands in PNAHelp. However, from the Programming Guide, there are two ways to find commands. 1. Using a 'finder' that looks like the UI. 2. A command tree. You could also click the help button on a dialog. From the help topic, find the Programming Icon. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 22:22 , Processed in 0.723634 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1317
