扫一扫,分享给好友
嗨,我想知道如何在excel电子表格中显示N5230A PNA_L网络分析仪的测试结果。
最初我试图将测试结果文件保存为.cti文件(citifile格式化数据)在拇指驱动器上,然后在PC上用excel打开它。 但是,我在excel上获得了许多不太合理的参数。 为了在excel中打开PNA测试结果,是否需要编写特定的宏? 我发现有人在附件中显示的excel电子表格中成功显示PNA网络分析仪的测试结果。 如果有人可以请给我提示并建议这样做会很棒。 提前致谢。 以上来自于谷歌翻译 以下为原文 Hi i am trying to find out how to display test results from the N5230A PNA_L network analyzer in an excel spread sheet. Originally i tried to save the test result file as .cti file (citifile formatted data) on a thumb drive and then open it with excel on a PC. However , i get a lot of different parameters on excel that don't really make sense. Is there a specific macro that i need to write in order to open the PNA test result in excel ? I found a picture of someone successfully displaying the test result from a PNA network analyzer on an excel spread sheet shown in the attached file. If anyone could please give me tips and advises to do this would be great. Thanks in advance. 附件
1个回答
您至少有3个选项:1-将您的盒子升级到C型号,它允许您安装最新的固件,让您可以选择以.csv格式保存数据,可以直接在Excel中打开。
2-使用现有的盒子和固件,您可以以.prn格式保存活动迹线的数据。 .prn格式与.csv完全相同。 实际上,如果在将.prn文件保存到.csv后更改.prn文件的扩展名,则可以直接在Excel中打开它。 .prn和.csv文件(在较新的固件中支持)之间的区别在于.prn一次只保存一条跟踪(活动跟踪)的数据,而PNA上的新.csv格式可以保存所有数据 显示在一个文件中。 3-您可以从Agilent网站下载名为Intuilink的工具(http://www.home.agilent.com/sec/product.jspx?cc=US&lc=eng&ckey=1000003731:epsg:pro&nid = -35491.536882050.00& id = 1000003731:epsg:pro)并使用它从Excel中远程连接到PNA。 此工具允许直接从分析仪将数据提取到Excel工作表中。编辑:daras于2012年4月27日上午9:58 以上来自于谷歌翻译 以下为原文 you have at least 3 options: 1- upgrade your box to a C model, which allows you to install the latest firmware, giving you the option of saving your data in a .csv format, which can directly be opened in Excel. 2- with your existing box and firmware, you can save the data for the active trace in a .prn format. the .prn format is exactly the same as .csv. in fact if you change the extension of the .prn file after you saved it to .csv, you can open it directly in Excel. the difference between a .prn and .csv file (supported in newer firmware) is that .prn saves only the data for one trace (the active trace) at a time, whereas the new .csv format on the PNA can save all data being displayed into a single file. 3- you can download a tool called Intuilink from the Agilent web site (http://www.home.agilent.com/sec/product.jspx?cc=US&lc=eng&ckey=1000003731:epsg:pro&nid=-35491.536882050.00&id=1000003731:epsg:pro ) and use it to remotely connect to the PNA from within Excel. this tool allows to pull data directly from the analyzer into an Excel worksheet. Edited by: daras on Apr 27, 2012 9:58 AM |
只有小组成员才能发言,加入小组>>
2134 浏览 1 评论
1915 浏览 1 评论
1764 浏览 5 评论
2638 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1605 浏览 4 评论
586浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
406浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
494浏览 0评论
2301浏览 0评论
1345浏览 0评论
GMT+8, 2024-7-4 04:07 , Processed in 1.207559 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
