电子发烧友论坛|
大家好,
如何在输入/输出板中使用FlipFlop? 我应该在XDC文件中使用什么约束? 谢谢! 以上来自于谷歌翻译 以下为原文 Hi All, How can I use a FlipFlop in the input/output pad? What constrain should I use in the XDC file? Thank you! |
4个回答
嗨@ dmitry1417,
set_property IOB TRUE [get_cells] 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, set_property IOB TRUE [get_cells Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
嗨@ dmitry1417,
您可以在XDC中将IOB属性设置为true。 有关用法,请参阅此链接的第46页:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug901-vivado-synthesis.pdf 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, You can set IOB atribute to true in XDC. Refer to page 46 of this link for usage: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug901-vivado-synthesis.pdf Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
你能提供整个约束线吗?
谢谢 以上来自于谷歌翻译 以下为原文 could you please provide the whole constraint line? Thank you |
嗨@ dmitry1417,
set_property IOB TRUE [get_cells] 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, set_property IOB TRUE [get_cells Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
3119 浏览 7 评论
3408 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2875 浏览 9 评论
3967 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3058 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1332浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1171浏览 1评论
/9
GMT+8, 2025-12-3 18:58 , Processed in 0.957854 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
556
