你好英特尔社区,
我目前正在运行带有三星40英寸LED电视的STK1AW32SC计算棒作为我的显示器。 棒每天晚上大约在下午6:30到晚上7:00左右定期关闭。 所有睡眠模式,节电模式和环保设置均在电视上关闭。 在摇杆本身,Windows Power设置被设置为永不休眠,我也在注册表中进行了更改,因此Stick不会休眠。 该棒还设置为显示数字标牌(来自Rise Vision)。 为数字标牌设定的时间表为上午6:30至晚上10:00。 直到下午6:30左右,如前所述,这种情况很有效,然后棒子会经常关闭。 我的问题是:英特尔棒上是否还有其他我不知道的节电设置,或者我可以做的其他注册表编辑? 我知道我的装备有相当数量的移动部件(电视,Rise Vision应用程序等),但我只需要排除英特尔端,如果有什么我错过了。 非常感谢任何回复,你们是最好的! 以上来自于谷歌翻译 以下为原文 Hello Intel Community, I am currently running a STK1AW32SC Compute Stick with a Samsung 40 Inch LED TV as my display. The stick periodically turns off by itself close to the same time each evening, roughly around 6:30 PM - 7:00 PM. All Sleep Mode, Power Saver and Eco Settings are off on the TV. On the stick itself, Windows Power settings are set so that it never sleeps and I also made a change in the Registry so the Stick does not hibernate. The stick is also set up to display digital signage (from Rise Vision). The schedule set for the digital signage is for 6:30 AM to 10:00 PM. This works great up until about 6:30 PM-ish, as mentioned prior and then the stick shuts down routinely. My Question is: Are there any other power saver settings on an Intel Stick that I'm not aware of or maybe other Registry edits that I can do? I am aware that my rig has a fair amount of moving parts (the TV, the Rise Vision app. etc), but I just need to rule out on the Intel end if there is anything I missed. Many thanks for any responses, you guys are the best! |
2个回答
如果它正在关闭,那么Windows中发生的事情就是它发生的原因。
如果是热带事件(即处理器过热并自行关闭以保护自身免受损坏),这将是由于(预定的)工作被要求做的结果。 但是,在这种情况下,您应该在重新启动时收到通知。 如果没有出现,那么它是Windows中的其他内容(预定事件或类似事件) 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 If it is shutting down, then something that is happening in Windows is responsible for it occurring. If it was a thermtrip event (i.e. the processor got too hot and shut itself down to protect itself from damage), this would be as a result of the (scheduled?) work that it is being asked to do. In this case, however, you should get a notification when you powered back on that this had occurred. If this is not appearing, then it is something else in Windows (scheduled event or something like that) Hope this helps, ...S |
tianyou15 发表于 2018-10-29 12:20 非常感谢斯科特! 我会调查你的建议,我忘了考虑棒是否会定期过热。 以上来自于谷歌翻译 以下为原文 Thanks so much Scott! I'll investigate your suggestions, I forgot to consider if the stick is periodically overheating. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 15:35 , Processed in 0.871684 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5740
