您好,我正在尝试设置AWG,并且我在第一次连接设备时遇到问题。
按照手册中的“入门”部分,我已经安装了IVI Compliance Package,IO Libraries Suite和设备驱动程序(我们的CD放错了位置,我直接从N8241A页面下载了驱动程序)。 我试图通过LAN连接到设备。 我的电脑通常有静态IP。 我删除了,因此没有与我的电脑相关联的IP地址。 我通过以太网将设备直接连接到我的计算机。 打开Keysight Connection Expert,我正在尝试添加新的LAN仪器。 我输入了设备上找到的主机名,并将TCPIP接口ID保留为默认值(TCPIP0)。 协议保留在默认的“Instrument”中,远程名称为“inst0”。 但是,测试VISA地址时,我只会收到超时错误。 我的问题是 - 我是否需要将设备连接到网络才能正确访问它? 此网络上没有DHCP,如果是这样,有没有办法静态地为设备分配一个? 否则,可能导致我的连接问题的其他因素是什么? 谢谢你,FrenchyRaoul 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to get an AWG set up, and I am having issues getting the device connected for the first time. Following the Getting Started section in the manual, I have installed the IVI Compliance Package, the IO Libraries Suite, and the driver for the device (our CD was misplaced, I downloaded the driver directly from the N8241A page). I am trying to connect to the device via LAN. My computer normally has a static IP. I deleted that, so there is no IP address associated with my computer. I have the device connected directly to my computer via Ethernet. Opening Keysight Connection Expert, I am trying to add a new LAN instrument. I have entered the hostname found on the device, and left the TCPIP Interface ID at the default (TCPIP0). The protocol is left at the default 'Instrument', with remote name 'inst0'. Testing the VISA address, however, I just get a timeout error. My questions are- do I need to connect the device to the network in order to properly access it? There is no DHCP on this network, so if so, is there a way to statically assign one to the device? Otherwise, what other factors might be causing my connection issues? Thank you, FrenchyRaoul |
3个回答
如果您可以先将N8241A连接到具有DHCP的网络,则可以使用DNS名称转到其网页。
到达那里后,您可以设置其静态IP,然后将其放回到其他网络上。 以上来自于谷歌翻译 以下为原文 If you can connect the N8241A to a network with DHCP first, then you can go to its webpage using the DNS name. Once you are there you can set its static IP, then put it back on your other network. |
MAX_zuo 发表于 2018-10-26 15:58 Hognala,谢谢你的回复。 我一定错过了手册中的内容。 我会试一试! 编辑:似乎有些东西不起作用。 我在一个带有DHCP的临时网络上设置了AWG,它似乎没有托管任何东西。 我尝试使用我的浏览器直接转到AWG的IP地址和主机名,两者都只是超时。 也就是说,我可以正常ping设备,所以我知道它在网络上并进行通信。 有什么想法吗?编辑:FrenchyRaoul于2014年11月12日下午3:08 以上来自于谷歌翻译 以下为原文 Hognala, Thank you for the reply. I must have missed this in the manual. I'll give it a shot! EDIT: It appears something is not working. I set up the AWG on a temporary network with DHCP, and it doesn't seem to be hosting anything. I tried using my browser to go directly to both the AWG's IP address as well as its host name, both just timing out. That said, I can ping the device fine, so I know it is on the network and communicating. Any thoughts? Edited by: FrenchyRaoul on Nov 12, 2014 3:08 PM |
这可以关闭。 我不确定发生了什么变化,但我现在可以连接到设备了。 以上来自于谷歌翻译 以下为原文 This can be closed. I'm not sure what has changed, but I can now connect to the device. |
只有小组成员才能发言,加入小组>>
1093 浏览 0 评论
2311 浏览 1 评论
2100 浏览 1 评论
1975 浏览 5 评论
2844 浏览 3 评论
857浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
626浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
726浏览 0评论
1414浏览 0评论
1094浏览 0评论
GMT+8, 2024-10-7 06:44 , Processed in 1.377113 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
