电子发烧友论坛|
嗨,
什么是NUC7i7DNBE的默认CPU核心热节流温度? (CPU开始降低频率的温度阈值,试图保持低于此温度限制) 我看到OEM通常在他们的系统中有不同的限制。 (85 - 100 C) 我们可以在BIOS或英特尔NUC上的软件中调整此温度限制吗? 感谢您的回答。 以上来自于谷歌翻译 以下为原文 Hi, what is default CPU core Thermal Throttling temperature for NUC7i7DNBE? (The temperature threshold where CPU starts lowering it's frequency to try to stay below this temperature limit) I see OEMs usually have different limits in their systems. (85 - 100 C) Can we adjust this temperature limit in BIOS or software on Intel NUCs? Thanks for your answer. |
3个回答
你好tom_rob,
感谢您加入此英特尔社区。 英特尔®NUC主板NUC7i7DNBE支持英特尔®酷睿™i7-8650U处理器。 根据https://ark.intel.com/,该处理器的Tjunction(即热量节流激活前核心可达到的最高温度)为100°C。 值得一提的是,处理器可能会短暂地超过Tjunction,而不会被认为是过热。 英特尔®酷睿™i7-8650U处理器>封装规格> Tjunction 现在,无法从BIOS更改Tjunction,因为油门温度可能因处理器和BIOS设置而异。 如果您的设备遇到高温,您可以按照以下步骤解决此问题。 1.加载默认BIOS设置。 2.让您的设备保持最新状态(如果需要,请更新BIOS)3。 在BIOS中更改风扇控制模式。 Wanner G.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello tom_rob, Thank you for joining this Intel Community. Intel® NUC Board NUC7i7DNBE supports the Intel® Core™ i7-8650U Processor. According to https://ark.intel.com/, the Tjunction (i.e the maximum temperature the cores can reach before thermal throttling activates) for this processor is 100°C. It is worth mentioning that the processor may exceed the Tjunction briefly without being considered overheating. Intel® Core™ i7-8650U Processor > Package Specifications > Tjunction Now, it is not possible to change the Tjunction from BIOS since throttle temperature can vary by processor and BIOS settings. If you unit experiences high temperatures, you can follow these steps to troubleshoot this issue. 1. Load default BIOS settings. 2. Keep your unit up to date (Update BIOS if needed) 3. Change the Fan Control Mode in BIOS. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
谢谢你的回答,它有所帮助。 因此,制造商可以在他们的系统中定制这种CPU热节流温度(因为它可以在具有相同CPU的OEM之间变化),但它不是最终用户可用的。 对? 以上来自于谷歌翻译 以下为原文 Thanks for your answer, it helped. So manufacturers can customize this CPU thermal throttling temperature in their systems (since it can vary between OEMs with the same cpu), but it is not something available to end user. Right? |
cd340823 发表于 2018-10-25 10:21 Hellotom_rob,我很高兴听到您发现所提供的信息很有帮助。**那么制造商可以在他们的系统中定制这个CPU热节流温度吗?是的,这是正确的。 系统制造商可以根据他们将要开发的平台/产品对其进行自定义。现在,请记住,这些信息可能无法公开获取,以防止系统冲突。 但是,您可能需要与系统制造商联系以获取有关它的更多信息.Wanner G.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello tom_rob, I am glad to hear that you found the information provided helpful. **So manufacturers can customize this CPU thermal throttling temperature in their systems? Yes, this is correct. System manufacturers can customize it depending on the platform/product they will be developing. Now, keep in mind that this information may not be available publicly in order to prevent system conflicts. However, you may need to contact the system manufacturer to get additional information about it. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-12 00:54 , Processed in 0.877880 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8937
