电子发烧友论坛|
嗨,我有一个带有i7-4710HQ的华硕ROG笔记本电脑。
CPU是Haswell,所以使用集成电压调节器FIVR。 我使用AVX2(例如AIDA64 FPU)对所有4个内核进行了压缩测试,在几分钟之后我注意到VR热限制引起的一些限制。 VR热限制警报由不同的软件(ThrottleStop,HWiNFO64等)标记。 我的问题:主板上的VRM或CPU封装上的集成FIVR是否达到VR热限制? 提前致谢。 以上来自于谷歌翻译 以下为原文 Hi, I have an Asus ROG notebook with a i7-4710HQ. CPU is Haswell, so with the integrate voltage regulatore FIVR. I OCed to 3.7 an all 4 cores and during stress test with AVX2 (AIDA64 FPU for example), after some minutes I notice some throttling caused by VR thermal limit. The VR thermal limit alert is flagged by different software (ThrottleStop, HWiNFO64, etc). My question: is it the VRMs on the motherboard or the integrated FIVR on the CPU package that hits the VR thermal limit? Thanks in advance. |
9个回答
Helloandreacos92,
感谢您的发表。 我们无法确认哪些VRMsthose工具正在识别,因为所提到的都不是官方的英特尔工具。 您需要与他们的相应开发团队确认,答案可能与他们用来标记RV热限制的代码有关。 艾米C. 英特尔客户支持技术人员 根据与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello andreacos92, Thank you for posting. We cannot confirm which VRMs those tools are identifying since none of the mentioned are an official Intel tool. You will need to confirm with their repective developing teams, the answer could be related to the code they use to flag the VR thermal limit. Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
嗨,艾米, 感谢您的答复。 是否存在报告VR热量限制的官方英特尔工具? 在XTU中,我只能看到热/功率/电流节流,但热量仅指核心温度。 谢谢,安德烈 以上来自于谷歌翻译 以下为原文 Hi Amy, thank you for the reply. Does exist any official Intel tool that reports VR thermal throttling? In XTU I can only see Thermal/Power/Current Throttling, but Thermal refers only on core temperature. Thanks, Andrea |
嗨再次,抱歉双帖。 HWiNFO64开发人员告诉我,HWiNFO使用MSR 0x690(MSR_INTEL_IA_PERF_LIMIT_REASONS)bit6和bit22来报告VR热警报状态,该状态在此情况下处于活动状态。 这可以帮忙吗? 再次感谢 以上来自于谷歌翻译 以下为原文 Hi again, sorry for double post. The HWiNFO64 developer told me that HWiNFO uses MSR 0x690 (MSR_INTEL_IA_PERF_LIMIT_REASONS) bit6 and bit22 to report VR Thermal Alert status, which is active in this case. Can this help? Thanks again |
jerry1978 发表于 2018-10-30 06:44 嗨安德里亚, 从我的角度来看,没有特定的软件可以读取VR Thermal状态。 我们的数据表显示只能使用处理器型号特定寄存器(MSR)通过软件接口读取。 HWiNFO64开发人员告诉我,HWiNFO使用MSR 0x690(MSR_INTEL_IA_PERF_LIMIT_REASONS)bit6和bit22来报告VR热警报状态,该状态在此情况下处于活动状态。 这可以帮忙吗? 是的,它确实有帮助。 实际上,设置VR Therm警报状态(R0)的MSR是MSR_CORE_PERF_LIMIT_REASONS 6.但是,我再次无法确认此特定MSR是否是第三方工具使用的MSR。 也许,通过这些信息,您可以与各自的开发团队确认。 您可以在此处查看MODEL-SPECIFIC REGISTERS(MSRS):https://software.intel.com/sites/default/files/managed/39/c5/325462-sdm-vol-1-2abcd-3abcd.pdf参见页面 2-210卷 4和Vol。 4 2-211。 您可以查看英特尔®酷睿™处理器(M / H处理器线)数据表,卷。 1此处:英特尔®酷睿™处理器(M / H处理器线)数据表,卷。 1 艾米C. 英特尔客户支持技术人员 根据与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hi Andrea, From my end there is not a specific software to read VR Thermal status. Our datasheet indicates that this can only be read with a software interface using processor Model Specific Register(MSR). The HWiNFO64 developer told me that HWiNFO uses MSR 0x690 (MSR_INTEL_IA_PERF_LIMIT_REASONS) bit6 and bit22 to report VR Thermal Alert status, which is active in this case.Yes, it does help. Actually, the MSR that sets the VR Therm Alert Status (R0) is MSR_CORE_PERF_LIMIT_REASONS 6. But, again I am not able to confirm if this specific MSR is the one used by the third-party tools in question. Maybe, with this piece of information you can confirm with their respective developing teams. You can check the MODEL-SPECIFIC REGISTERS (MSRS) here: https://software.intel.com/sites/default/files/managed/39/c5/325462-sdm-vol-1-2abcd-3abcd.pdf See page 2-210 Vol. 4 and Vol. 4 2-211. You can check the Intel® Core™ Processors (M/H-Processor Lines) Datasheet, Vol. 1 here: Intel® Core™ Processors (M/H-Processor Lines) Datasheet, Vol. 1 Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
60user38 发表于 2018-10-30 07:03 再次感谢艾米, 我已向开发人员询问HWiNFO是否使用了您报告的相同位(MSR_CORE_PERF_LIMIT_REASONS位6)。 如果是的话,你能否告诉我这是指CPU内部的VR还是主板VRM? 在数据表中我没有找到这些信息。 再次感谢, 安德里亚 以上来自于谷歌翻译 以下为原文 Thank you again Amy, I've asked to the developer if HWiNFO uses the same bit you reported (MSR_CORE_PERF_LIMIT_REASONS bit 6). If yes, can you tell me if this refers to the VR inside the CPU's FIVR or to the motherboard VRMs? In the datasheet I didn't find this information. Thanks again, Andrea |
60user38 发表于 2018-10-30 07:10 安德烈, 根据英特尔®64和IA-32架构软件开发人员手册文档,为处理器设置VR Therm Alert Status(R0)的MSR为MSR_CORE_PERF_LIMIT_REASONS位6.该寄存器对基于该文档的处理器有效。 主板的VRM可能使用不同的寄存器,因此需要与华硕联系。 我建议等待HWiNFO响应,他们可以确认这是否是他们用来在他们的工具中报告VR Therm Alert的寄存器。 英特尔®64和IA-32架构软件开发人员手册:https://software.intel.com/sites/default/files/managed/39/c5/325462-sdm-vol-1-2abcd-3abcd.pdf 艾米C. 英特尔客户支持技术人员 根据与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Andrea, According to the Intel® 64 and IA-32 Architectures Software Developer’s Manual Document, the MSR that sets VR Therm Alert Status (R0) for the processor is MSR_CORE_PERF_LIMIT_REASONS bit 6. This register is valid for the processor based on that document. It's possible that the motherboard's VRMs use different register and for that you will need to check with ASUS. I would recommend to wait for the HWiNFO response, they might be able to confirm if this is the register they use to report in their tool the VR Therm Alert. Intel® 64 and IA-32 Architectures Software Developer’s Manual: https://software.intel.com/sites/default/files/managed/39/c5/325462-sdm-vol-1-2abcd-3abcd.pdf Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-30 07:17 嗨,艾米, HWiNFO开发人员已经确认我这是用于在其工具中报告VR热警报的寄存器。 那么,您是否确认我们在谈论英特尔处理器中的集成VR? 再次感谢你, 安德里亚 以上来自于谷歌翻译 以下为原文 Hi Amy, HWiNFO developer already confirms me that this is the register It uses to report in its tool the VR Thermal Alert. So, do you confirm that we are speaking of the integrated VR in the Intel Processor? Thank you again, Andrea |
安德烈, 是的,我们说的是为处理器设置VR Therm Alert Status(R0)的MSR。 您可以在英特尔®64和IA-32架构软件开发人员手册第2-210页中确认这一点。 4和Vol。 4 2-211。 艾米C. 英特尔客户支持技术人员 根据与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Andrea, Yes, we are speaking of the MSR that sets VR Therm Alert Status (R0) for the processor. You can confirm this in the Intel® 64 and IA-32 Architectures Software Developer’s Manual page 2-210 Vol. 4 and Vol. 4 2-211. Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-30 07:44 HiAndrea,我希望这些信息有用,如果您需要进一步的帮助,请告诉我们.Amy CIntel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hi Andrea, I hope this information was useful, and if you need further assistance let us know. Amy C Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-14 16:04 , Processed in 0.926222 second(s), Total 58, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2188
