电子发烧友论坛|
我们使用BCM433芯片,并通过WICE 3.7.0~7实现蓝牙连接的过程。在该部分的数据表中,在第115页,它指出“BCM4340不提供同时2.4 GHz和5 GHz的操作”。由于BLE被放置在芯片的2.4GHz部分,这个陈述是否意味着如果使用5GHz AP来进行WiFi接入,那么BLE就不能使用?
以上来自于百度翻译 以下为原文 We use a BCM43340 chip and are in the process of implementing bluetooth connection through WICED 3.7.0-7. In the datasheet for the part, on page 115, it states that "The BCM43340 does not provide simultaneous 2.4 GHz and 5 GHz operation". Since the BLE is housed in the 2.4GHz portion of the chip, does this statement mean that BLE cannot be used if using a 5GHz AP for wifi access? |
2个回答
你的理解是正确的。数据表和示意图似乎表明,如果使用5 GHz AP用于WiFi接入,则不能使用BLE。验证这一点的一种方法是测试BLYWiFixIdvor应用程序,在那里连接到5 GHz AP并检查连接是否被维护。
以上来自于百度翻译 以下为原文 Your understanding is correct. The datasheet and schematic seem to indicate that BLE cannot be used if using a 5 GHz AP for wifi access. One way to validate this is by testing the ble_wifi_introducer App where you connect to a 5 GHz AP and check the connection is maintained or not. |
chm5 发表于 2018-10-24 10:42 CrSON.KRUPPE223 29 926 RROY 我在内部检查了WiFi组合芯片产品团队,它似乎所有我们目前的组合设备(如CYW4345和其他)利用分立PHY,MAC和共享天线,所以5GHz的无线局域网和2.4GHz的BT同时是可能的(即5G SwiTAP与BLE)。 我们有一个设备,今年晚些时候,可以利用一个双天线路径和LNA,这将是最佳的2.4GHz无线局域网和同时BT。 记住,原来的问题是同时引用5GHz WLAN和2.4GHz BT,而不是2.4GHz WLAN和5GHz无线局域网——这只有RSDB才可能。 希望这有帮助。 以上来自于百度翻译 以下为原文 carson.krupp_2329926 rroy I checked internally with the WiFi Combo chip product team and it appears that all of our current combo devices (ex. CYW43455 and others) leverage a seperate PHY, MAC and shared antenna, so 5GHz WLAN and 2.4GHz BT simultaneously is indeed possible (i.e. 5G softAP with BLE). We have a device coming out later in the year which can take advantage of a dual antenna path and LNAs, and this will be optimal for 2.4GHz WLAN and simultaneous BT. Remember though that the original question references 5GHz WLAN and 2.4GHz BT simultaneously – not 2.4GHz WLAN and 5GHz WLAN – that’s only possible with RSDB. Hope this helps. |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7459 浏览 0 评论
2492 浏览 1 评论
2184 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2095 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7943浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6514浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
736浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8366浏览 2评论
/9
GMT+8, 2025-12-17 13:11 , Processed in 0.762685 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5044
