大家好
我在自定义主板上使用了一些VL6180X设备。 然后,它们的范围偏移似乎每次启动都会改变大约mm5mm,尽管我按应用说明中的指示调整了偏移。 什么影响范围偏移? 在正常情况下,只需一次调整就够了吗? 这个问题特定于我的董事会吗?有没有人有同样的问题? 最好的祝福, 石川 #proximity-sensor#multiple-vl6180x #offset#vl6180 以上来自于谷歌翻译 以下为原文 Hi, all I'm using some VL6180X devices on my custom board. Then, their range offset seem to change every start up about �5mm, although I adjust the offset as directed in application note. What affects the range offset? Under normal circumstances, is it enough with only once adjustment? Is this problem specific to my board?Does anyone has the same issue? Best regards, Ishikawa #proximity-sensor #multiple-vl6180x #offset #vl6180 |
4个回答
偏移数据不存储在传感器内。程序应该是:
按照偏移校准程序获取偏移结果。将偏移结果保存在CPU的内存中。每次重启时,重新编程偏移寄存器。 以上来自于谷歌翻译 以下为原文 The offset data is NOT stored within the sensor. The procedure should be:
你好,约翰
感谢您的回复,我为迟到的回复道歉。 请让我问一个关于以下内容的问题: >偏移数据不存储在传感器内。 本文档中有以下代码( http://www.st.com/content/ccc/resource/technical/document/datasheet/c4/11/28/86/e6/26/44/b3/DM00112632.pdf/files/DM00112632.pdf/jcr:内容/翻译/ en.DM00112632.pdf 零件到零件范围偏移在制造期间被校准并存储在NVM中。 VL6180的NVM中是否保持偏移值? 根据这份文件( https://my.st.com/content/ccc/resource/technical/document/user_manual/group0/ba/47/75/5e/d2/80/47/7e/DM00247018/files/DM00247018.pdf/jcr:内容/翻译/ en.DM00247018.pdf ),VL6180有一个NVM。 最好的祝福 石川 以上来自于谷歌翻译 以下为原文 Hi, john Thank you for your response and I apologize my late reply. Please let me ask you a question about the following: >The offset data is NOT stored within the sensor. There are the following codes in this document ( http://www.st.com/content/ccc/resource/technical/document/datasheet/c4/11/28/86/e6/26/44/b3/DM00112632.pdf/files/DM00112632.pdf/jcr:content/translations/en.DM00112632.pdf ).>The part-to-part range offset is calibrated during manufacture and stored in NVM. Isn't the offset value hold in the VL6180's NVM? According to this document( https://my.st.com/content/ccc/resource/technical/document/user_manual/group0/ba/47/75/5e/d2/80/47/7e/DM00247018/files/DM00247018.pdf/jcr:content/translations/en.DM00247018.pdf ), VL6180 has a NVM. Best regards Ishikawa |
你好,约翰
请让我再问你一个问题。 >我在自定义主板上使用了一些VL6180X设备。 然后,它们的范围偏移似乎每次启动都会改变大约±5mm,尽管我按应用说明中的指示调整偏移。 >影响范围偏移的因素是什么? 现在,我补偿范围数据如下: 1.转到我的董事会 2.将传感器前面的白板放在50mm处 3.多次记录范围数据 4.按照应用说明4.1.1的程序计算补偿 https://cdn.sparkfun.com/datasheets/Sensors/Proximity/VL6180_ApplicationNote.pdf 目前,我每次重启都会重复此过程。 但是,这非常麻烦。 有一次,我打算通过将数据保存在我的文件中来重用偏移数据, 但是当我重新启动我的电路板时,偏移数据似乎不合适。 如果我重新启动电路板,我可以重复使用偏移数据吗? 最好的reagrds 石川 以上来自于谷歌翻译 以下为原文 Hi, John Please let me ask you a question again. >I'm using some VL6180X devices on my custom board. Then, their range offset seem to change every start up about ±5mm, although I adjust the offset as directed in application note. >What affects the range offset? Now, I compensate the range data like following: 1.turn on my board 2.put a white board in front of the sensor at 50mm 3.get the range data many times 4.calculate the offset in accordance with procedure of application note 4.1.1 https://cdn.sparkfun.com/datasheets/Sensors/Proximity/VL6180_ApplicationNote.pdf At present, I repeat this procedure every restart. However, this is very very bothersome. Once, I intended to reuse the offset data by saving the data in my file, but when I restarted my board, the offset data seemed to be inappropriate. Can I reuse the offset data, if I restart the board? Best reagrds Ishikawa |
一旦进行了偏移校准,它永远适用于该芯片。进行校准,从芯片读取校准数据并将其存储在您的应用程序中。重启时,将保存的校准数据写入传感器。
以上来自于谷歌翻译 以下为原文 Once you do the offset calibration, it's good for that chip forever. Do the calibration, read the cal data from the chip and store it in your application. At reboot, write the cal data you saved to the sensor. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1483 浏览 1 评论
2153 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1511 浏览 1 评论
2843 浏览 6 评论
5281 浏览 21 评论
367浏览 4评论
565浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
283浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
645浏览 3评论
539浏览 3评论
GMT+8, 2024-4-28 16:53 , Processed in 0.743950 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
