你好,
我计划建立一个基于磁场传感器(理想情况下是3轴)的液位传感系统的概念,它将位于滤罐的底部并在表面钕磁铁上流动。您可以建议使用什么传感器进行测试(我假设可能是最敏感的,并且具有数字前端烘烤功能,以便将噪音降至最低)。 该测试将帮助我确定传感器和磁铁可以运行多远,提供可靠的信息,以及其他因素可能影响读数。非常感谢advnace 亚采 以上来自于谷歌翻译 以下为原文 Hello, I am planning to build a concept of level sensing system based on the magnetic field sensor ( ideally 3 axis ) which will be located on the bottom of the canister and flowing on the surface neodymium magnet. What Sensor you could suggest to be used for testing ( I am assume maybe the most sensitive and with digital front end baked-in in order to reduce noise to minimum ). The test will help me to determine how far sensor and magnet could operate giving an reliable information, and also what other factors could affect the readings. Thanks a lot in advnace Jacek |
2个回答
请考虑磁通密度与距离的相关性。
钕磁铁的磁通密度非常高,而MEMS磁力计的磁通密度非常低。 以上来自于谷歌翻译 以下为原文 Please consider dependency of magnetic flux density vs distance. Magnetic flux density of neodymium magnet is very high on the contrary the range on MEMS magnetometer is quite low. |
理解...
这就是我在寻找什么类型的建议的原因。使用塑料罐底部的HMC5883L进行了一些测试,并在水面上使用浮动的小钕磁铁。我能够在从传感器到磁铁的大约40-50cm的范围内获得非常好的读数。唯一的问题就像你提到的那个领域是如此强大,当水平下降信号增加非常大,所以也许不同的传感器可以更好地工作。 非常感谢,就像我之前提到的那样,这只是探索这个时间点潜在的技术解决方案。所以也许这个想法不是一个可行的解决方案。 以上来自于谷歌翻译 以下为原文 Understand... That is the reason I am looking for advice what type. Have run some tests using the HMC5883L on the bottom of the plastic canister , and with the floating small neodymium magnet on the surface of the water. I was able to get quite nice readings in the range to about 40-50cm from sensor to magnet. The only problem is like you mention the field is so strong that when the level is dropping signal increase very heavily so maybe different sensor could works better. Thanks a lot, and like I am mention earlier it is just exploration at this point of time potential technical solution. So maybe this idea is not an viable solution. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2725 浏览 1 评论
3237 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1807 浏览 1 评论
3646 浏览 6 评论
6034 浏览 21 评论
1336浏览 4评论
197浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
442浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
270浏览 2评论
GMT+8, 2024-12-22 13:55 , Processed in 1.242279 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
