电子发烧友论坛|
我试图做一个电力预算,并决定是否安全,写一个日志闪光灯时,我的可充电电池正在死亡,但仍然有一定的能力留下。
但是我找不到关于Flash要写多少电流的规格。我使用CYBLY-214015模块(它包含CY8C4248的一些味道,我相信)。这有256K的闪光。 是否有这个写操作的最大电流值? 谢谢! 以上来自于百度翻译 以下为原文 I'm trying to do a power budget and decide whether it's safe to write a log to flash when my rechargeable battery is going dead but still has some capacity left. But I can't find any specs on how much more current it takes to write to flash. I'm using the CYBLE-214015 module (which contains some flavor of CY8C4248, I believe). This has 256K of flash. Does anyone have a maximum current value for this write operation? Thanks! |
2个回答
韦尔经验测量将是你最好的选择。
请记住,Flash写入需要一定量的电流在一段时间内完全写入,因此使用“电荷”。但是,电流抽出电压下降,如果电压降得太远,那么芯片将断电、复位或行为失常,因此,您可以写入闪光灯的有效点将处于比您想象的更高的充电状态。闪存需要更高的CPU速度,但这将提速更快的电流肯定。在猜测中,我会说在写闪光灯的时候会画出25 +mA的电流,但我现在正在猜测。 以上来自于百度翻译 以下为原文 Welll.. empirical measurement would be your best bet. Keep in mind that the flash write takes some amount of current over a period of time to write fully, thus a total "charge" used. But, current draw drops voltage, and if the voltage drops too far, then the chip will power off, reset, or behave erratically, thus the effective point at which you can write to flash would be at a higher recharge state than you might think. The flash requires higher CPU speed however, which will draw faster current for sure. At a guess, I would say 25+ mA of current would be drawn when writing the flash, but I am guessing at this point. |
程序/擦除期间的闪光灯电流应为10mA。但是其他块需要一起考虑。
谢谢, 赖安 以上来自于百度翻译 以下为原文 The flash cells current during program/erase should be ~10mA. But other blocks requires to be considered in together. Thanks, Ryan |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7070 浏览 0 评论
2474 浏览 1 评论
2165 浏览 1 评论
4030 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7561浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6110浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7954浏览 2评论
/9
GMT+8, 2025-12-1 11:13 , Processed in 0.868140 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1510
