我正在尝试使用MMCM创建一个5 MHz时钟。
我的设计中有一个60 MHz的时钟,但我不确定在coregen中为一些参数添加了什么。 在第1页:我应该为“输入抖动”和源(单端时钟功能引脚,差分时钟功能引脚,全局缓冲器,无缓冲器)添加什么? 在第2页:我应该为“驱动器”(BUFGCE,BUFHCE)做什么? 我知道源可能取决于输入时钟的细节,但我真的不知道从哪里开始寻找,所以我将不胜感激任何帮助。 我确定我错过了一些必要的信息,所以请解释一下你需要知道什么来帮助我。 非常感谢。 以上来自于谷歌翻译 以下为原文 I am trying to create a 5 MHz clock with enable using the MMCM. I have a 60 MHz clock in my design, but I am not sure what to put for some parameters in coregen. On Page 1: What should I put for "Input Jitter" and source (Single Ended Clock Capable Pin, Differential Clock Capable Pin, Global Buffer, No Buffer)? On Page 2: What should I put for "Drives" (BUFGCE, BUFHCE)? I understand the source might depend on the particulars of the input clock, but I really don't know where to start looking, so I would appreciate any help. I'm sure I missed some information that is required, so please explain what you need to know to help me. Thank you so much. |
9个回答
是,
如果在多个地区需要它,那么它就是全球性的。 由于您已经在设计中使用了时钟,并且如果它已经在BUFG上,输出信号名称现在可以连接到其他东西。 Austin Lesea主要工程师Xilinx San Jose 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Yes, If it is needed in more than one region, that makes it global. Since you already have the clock in your design, and if it is already on a BUFG, the output signal name may now be connected to something else. Austin Lesea Principal Engineer Xilinx San JoseView solution in original post |
好,
你想要什么? 60 MHz时钟输入来自某处,并且有一些抖动。 如果你不知道的话,我会输入50 ps,因为晶体振荡器源的频率从25ps到可能高达100ps,具体取决于它们的质量。 至于输出是什么驱动的:它是在全球范围内,在本地使用吗? BUFG是全局缓冲区。 请查看MMCM用户指南,了解详细信息。 http://www.xilinx.com/support/documentation/user_guides/ug362.pdf Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Well, What do you want? A 60 MHz clock input comes from somewhere, and has some jitter. I would put in 50 ps, if you do not know, as cyrstal oscillator sources are from 25ps to perhaps as much as 100ps, depending on their quality. As for what the output is driving: is it to be used globally, locally? A BUFG is the global buffer. Look at thge MMCM user's guide for the details. http://www.xilinx.com/support/documentation/user_guides/ug362.pdf Austin Lesea Principal Engineer Xilinx San Jose |
谢谢奥斯汀。
我在.PAR文件中找到了这个。 clkm是我的MMCM输入clk所以我应该将源设置为全局缓冲区,对吧? ************************** 生成时钟报告 ************************** + --------------------- + -------------- + ------ + ----- - + ------------ + ------------- + | 时钟网| 资源|锁定|扇出|净偏差(ns)|最大延迟(ns)| + --------------------- + -------------- + ------ + ----- - + ------------ + ------------- + | clkm | BUFGCTRL_X0Y31 | 没有| 4612 | 0.455 | 2.035 | 我阅读了这份文件,这是非常好的信息。 我很确定我有可用的BUFG,但时钟仅用于一个组件,尽管它占整个设计的40%左右。 虽然全球时钟和本地时钟之间有什么区别? 我相信不止一个地区需要时钟,那么它是否具有全球性? 谢谢 以上来自于谷歌翻译 以下为原文 Thanks Austin. I found this in my .PAR file. clkm is my MMCM input clk so I should set the source as global buffer, right? **************************Generating Clock Report**************************+---------------------+--------------+------+------+------------+-------------+| Clock Net | Resource |Locked|Fanout|Net Skew(ns)|Max Delay(ns)|+---------------------+--------------+------+------+------------+-------------+| clkm |BUFGCTRL_X0Y31| No | 4612 | 0.455 | 2.035 |I read the document and it was pretty good information. I'm pretty sure I have available BUFG's, but the clock is only used in one component, although it is about 40% of the whole design. What is the difference between global vs local clocks though? I believe the clock will be needed in more than one region, so does that make it global? Thanks |
是,
如果在多个地区需要它,那么它就是全球性的。 由于您已经在设计中使用了时钟,并且如果它已经在BUFG上,输出信号名称现在可以连接到其他东西。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Yes, If it is needed in more than one region, that makes it global. Since you already have the clock in your design, and if it is already on a BUFG, the output signal name may now be connected to something else. Austin Lesea Principal Engineer Xilinx San Jose |
它被扇出(连接)到超过4,000个其他元素(负载)。
Austin Lesea首席工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 It is fanned out (connected) to over 4,000 other elments (loads). Austin Lesea Principal Engineer Xilinx San Jose |
尝试在PlanAhead中进行合成时出错。
如果我的时钟缓冲区将用于可重新配置的分区,那么我必须选择BUFHCE,而不是BUFGCE? 以上来自于谷歌翻译 以下为原文 I have gotten an error when trying to synthesize in PlanAhead. If my clock buffer is going to be used in a reconfigurable partition, then I must choose BUFHCE, not BUFGCE? |
是。
可重配置性增加了许多限制。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Yes. Reconfigurability adds a number of restrictions. Austin Lesea Principal Engineer Xilinx San Jose |
我需要提前注意的任何其他限制吗?
我希望有一个覆盖多个时钟域的动态分区。 我最好将缓冲区作为BUFGCE放在静态逻辑中还是在可重构逻辑中使用BUFHCE? 以上来自于谷歌翻译 以下为原文 Any other restrictions that I need to be aware of ahead of time? I wish to have a dynamic partition covering multiple clock domains. Am I better off putting the buffer as a BUFGCE in the static logic or having a BUFHCE in the reconfigurable logic? |
我建议将基本结构内容放在不可重新配置的部分中。
IO,时钟等都是最好的保持静态。 随心所欲地改变逻辑。 这是最简单和最容易做到的事情,并且会导致最少的头痛和问题。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 I recommend putting the basic structure stuff in the non-reconfigurable part. IO, clocks, etc. are best all kept static. Change the logic all you wish. That is the simplest and easiest to do, and will lead tio the fewest headaches and problems. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
2396 浏览 7 评论
2811 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2278 浏览 9 评论
3356 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2445 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
782浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
558浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
405浏览 1评论
1985浏览 0评论
705浏览 0评论
GMT+8, 2024-12-4 09:27 , Processed in 1.245416 second(s), Total 62, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
