我对我的申请有疑问。
我想我已经知道了答案,但问一下也没什么坏处。 以下信息是我想要做的:我想从下面的3个信号中连续捕获值。 1.模拟脉冲2.模拟信号3.带有dbc.files的CAN数据我可能会对模拟脉冲进行边沿触发,因为另外两个信号是脉冲的计算值。 我需要测量以下内容:1。信号的最小值1 2.信号的下降时间1 3.信号的y光标值2 4.特定的CAN消息模式是重复的,它们可以达到25Hz的最大频率。 因此,我们的想法是不进行单次触发并捕获测量结果。 我想连续测量每一个事件。 目前我使用matlab进行编程(不是vB或C#proficient:p)。 我知道理想情况下人们会使用可能来自NI的DAQ设备来做这种事情,但我想知道我是否可以用oscope来做。 以上来自于谷歌翻译 以下为原文 I have a question regarding my application. I think I already know the answer but it doesn't hurt to ask. The following information is what I am wanting to do: I would like to continuously capture values from 3 signals below. 1. Analog pulse 2. Analog signal 3. CAN data with dbc.files I would probably do an edge trigger on the analog pulse as the other two signal is a somewhat a calculated value of the pulse. I would need measurement of the following: 1. minimum of signal 1 2. fall time of signal 1 3. y-cursor value of signal 2 4. specific CAN message The pattern are repetitive and they can go up to max freq of 25Hz. So the idea is not to do single trigger and capture the measurements. I would like continuous measurement of every single events. Currently I do programming using MATLAB (not vB or C# proficient :p). I know ideally people would use DAQ devices probably from NI to do this kind of stuff but was wondering if I can do it with oscope. |
1个回答
通常,示波器不能提供连续数据记录的能力。
它们捕获数据,处理数据,执行解码(如果指定),显示,然后获取更多数据。 它们在处理,解码和显示过程的部分期间是盲目的。 还有其他工具,如数字化仪,可以提供连续的数据捕获,但它们通常没有任何内置的测量或解码功能。 人 以上来自于谷歌翻译 以下为原文 Oscilloscopes do not, generally, provide the ability to do continuous data logging. They capture data, process the data, do the decode, if specified, display, then take more data. They are blind during the processing, decode, and display portions of the process. There are other tools, such as digitizers, that can provide continuous data capture, but they don't usually have any built-in measurement or decode capability. Al |
只有小组成员才能发言,加入小组>>
1130 浏览 0 评论
2318 浏览 1 评论
2109 浏览 1 评论
1985 浏览 5 评论
2858 浏览 3 评论
879浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
648浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
748浏览 0评论
1445浏览 0评论
1133浏览 0评论
GMT+8, 2024-10-19 23:43 , Processed in 1.742681 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
