我试图把例子从EEPROM的例子:
CE195313 PSOC仿真EEPROM 进入我的项目。 但是,当我编译代码时,它会生成EMyEEPROMYCONFIG作为const,因此当我用下面的行编译时会引起警告: EEPROFRESUTVALL=CyyMeMeEnPosithInIT(&EMMEEEPROMYCONFIG,和EMEEEEPROMFIX上下文); 警告是: prj.m0121:传递参数1“cy_em_eeprom_init”弃“const”限定符的指针目标型[ wdiscarded预选赛] 示例项目不生成此为const,但我确实在PSoC Creator 4.2。 如有任何帮助,我们将不胜感激。 谢谢 以上来自于百度翻译 以下为原文 I'm trying to incorporate the example from the eeprom example: CE195313 PSoC Emulated EEPROM into my project. However when I compile the code, it generates Em_EEPROM_config as a const, and therefore causes warnings when I compile with the following line: eepromReturnValue = Cy_Em_EEPROM_Init(&Em_EEPROM_config, &Em_EEPROM_context); The warning is: prj.M0121: passing argument 1 of 'Cy_Em_EEPROM_Init' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers] The example project does not generate this as a const, but mine does in PSoC Creator 4.2. Any help would be much appreciated. Thanks |
4个回答
你能附上你的项目吗?在示例项目中,没有声明为const。
外部的CysStCyEEPROMYCONTICONT EMMEEEPROFIX配置; 这是声明为类型cy_stc_eeprom_config_t类型的一个变量,实际申报的是里面的文件em_eeprom C. 谢谢, 希马 以上来自于百度翻译 以下为原文 Can you please attach your project. In the example project this is not declared as a const. extern cy_stc_eeprom_config_t Em_EEPROM_config; This is declared as a variable of type cy_stc_eeprom_config_t type.The actual declaration is inside the file Em_EEPROM.c. Thanks, Hima |
60user67 发表于 2018-10-12 15:05 对不起,我不能分享这个项目。 如果在一个TopDead窗口中创建一个仿真EEPROM块并编译,它是否将concong生成为const?如何生成它来匹配示例项目? 以上来自于百度翻译 以下为原文 I'm sorry, I cannot share the project. If you create an emulated EEPROM block in one of your TopDesign windows and compile, does it generate the config as a const? How do I get it to generate it to match the example project? |
你好,
您能确保在“EMFEEPROM组件配置”窗口内置的选项卡中“Flash配置数据”选项未被选中。 谢谢, 希马 以上来自于百度翻译 以下为原文 Hello , Can you make sure that the "Config Data in Flash" option is unchecked in the Em_EEPROM component configuration window Built-in tab. Thanks, Hima |
那是固定的。谢谢您! 以上来自于百度翻译 以下为原文 That fixed it. Thank you! |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 00:00 , Processed in 5.505829 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2719
