电子发烧友论坛|
有谁知道传感器的灵敏度和偏移如何在很大的温差下发生变化?
应用说明说: ''TCSo - 灵敏度随温度变化:此参数定义灵敏度 随温度变化。例如,在 2.0g满量程范围内,灵敏度 变化在 0.01%/ C。因此,如果环境温度发生变化 40°C,从25°C到65°C,灵敏度变化范围为 0.01%* 40 = 0.4%,这意味着超过40 C的灵敏度变化在0.996 mg / LSB之内 1.004 mg / LSB,表明灵敏度相对于温度非常稳定 更改。因此,可以忽略灵敏度的温度补偿。'' 这是否意味着如果我将温度提高40 C,他们不知道灵敏度会在哪个方向发生变化?这意味着''灵敏度变化。数据表中的温度'对我来说根本不会帮助我。 #lis3dsh #temperature 以上来自于谷歌翻译 以下为原文 Does anyone knows how the sensors sensitivity and offset changes over a big temperature difference? Application Note says: ''TCSo - Sensitivity change vs. temperature: This parameter defines how sensitivity changes with temperature. For example, at a �2.0 g full-scale range, the sensitivity changes within �0.01%/�C. Therefore, if the environmental temperature changes 40 �C, from 25 �C to 65 �C, then the sensitivity changes within the range of �0.01% * 40 = �0.4%, which means the sensitivity change over 40 �C is within 0.996 mg/LSB and 1.004 mg/LSB, which shows that the sensitivity is very stable versus temperature change. Thus, temperature compensation for sensitivity can be ignored.'' Does this mean that they didn't know in which direction the Sensitivity will change if i increase the temperature by 40�C? That would mean the ''Sensitivity changevs. temperature'' in the datasheet would't help me at all. #lis3dsh #temperature |
2个回答
灵敏度在内部通过温度补偿,因此传感器TCSo通常非常低±0.01%/°C。
你不必做任何其他的温度补偿。 对温度的敏感性依赖不必是单调的,因此不可能只说它有正号或负号。 最好的祝福 米罗斯拉夫 以上来自于谷歌翻译 以下为原文 The sensitivity is internally compensated over temperature so the sensor TCSo is typically very low ±0.01%/°C. You don’t have to do any other temperature compensation. Sensitivity dependence on temperature doesn’t have to be monotonous so it not possible to say only if it has positive or negative sign. Best regards Miroslav |
我在论坛和描述中读到每个传感器都有特定的温度依赖性。
正如我的实验所示,在很宽的温度范围内,加速度计和陀螺仪的读数需要根据温度进行调整 。 另见主题https://community.st.com/message/205156-lsm6dsl-lsm303agr-lsm9ds1-temperature-dependence 以上来自于谷歌翻译 以下为原文 I read on the forums and in the descriptions that each sensor has a particular temperature dependence. And as my experiments have shown in a wide temperature range, the readings of the accelerometer and the gyroscope need to be adjusted depending on the temperature . See also topic https://community.st.com/message/205156-lsm6dsl-lsm303agr-lsm9ds1-temperature-dependence |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1454 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1503 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3650 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
728浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 18:14 , Processed in 2.881240 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2771
