LIS3DSH有一个三通道10位A / D转换器,但我找不到任何信息。
准确度是多少? (如果需要,我可以将一个通道连接到电压参考以进行校准) 输入电压范围是多少? 最大输入电流是多少? (我需要缓冲频道) #lis3dsh 以上来自于谷歌翻译 以下为原文 The LIS3DSH has a three channel 10 bit A/D converter but I can't find any information on it. What is the accuracy? (I could tie one channel to a voltage reference for calibration if necessary) What is the input voltage range? What is the maximum input current? (will I need to buffer the channels) #lis3dsh |
2个回答
我想你的意思是LIS3DH,因为LIS3DSH没有辅助ADC。
然后,你可以检查此:[死链接/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/Flat.aspx?RootFolder=/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/LIS3DH%20ADC%20Specifications&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004224A862E061BB4BADDEF313D70857E6&TopicsView=https ://my.st.com/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/AllItems.aspx& currentviews = 316] https://my.st.com/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/Flat.aspx ?RootFolder =%2fpublic%2fSTe2ecommunities%2fmems_sensors%2fLists%2fAccelerometers%2fLIS3DH%20ADC%20Specifications&安培; FolderCTID = 0x01200200770978C69A1141439FE559EB459D7580004224A862E061BB4BADDEF313D70857E6&安培; TopicsView = HTTPS%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmems_sensors%2FLists%2FAccelerometers%2FAllItems% 2Easpx&安培; currentviews = 316 最好的祝福 米罗斯拉夫 以上来自于谷歌翻译 以下为原文 I suppose you mean LIS3DH, because LIS3DSH does not have auxiliary ADC. Then you can check this: [DEAD LINK /public/STe2ecommunities/mems_sensors/Lists/Accelerometers/Flat.aspx?RootFolder=/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/LIS3DH%20ADC%20Specifications&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004224A862E061BB4BADDEF313D70857E6&TopicsView=https://my.st.com/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/AllItems.aspx¤tviews=316]https://my.st.com/public/STe2ecommunities/mems_sensors/Lists/Accelerometers/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmems_sensors%2fLists%2fAccelerometers%2fLIS3DH%20ADC%20Specifications&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004224A862E061BB4BADDEF313D70857E6&TopicsView=https%3A%2F%2Fmy%2Est%2Ecom%2Fpublic%2FSTe2ecommunities%2Fmems_sensors%2FLists%2FAccelerometers%2FAllItems%2Easpx¤tviews=316 Best regards Miroslav |
感谢1,200mV,+ -400mV,8或10位,具体取决于模式。虽然没有提到输入电流,但我认为它确实需要缓冲。感谢您更正了部件号。
以上来自于谷歌翻译 以下为原文 Thanks 1,200mV, +-400mV, 8 or 10 bit depending on mode. The input current is not mentioned though so I will assume that it does need buffering. Thanks for correcting the part number. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2452 浏览 1 评论
3159 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1726 浏览 1 评论
3544 浏览 6 评论
5904 浏览 21 评论
883浏览 4评论
1261浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
527浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1244浏览 3评论
1298浏览 3评论
GMT+8, 2024-9-29 00:59 , Processed in 1.102176 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
