大家好。
请帮助我将测量数据从示波器DSOX4022A保存到我的PC使用labview。 我发现只能将数据保存到USBstick,但我需要将大量曲线保存到PC。 提前致谢 以上来自于谷歌翻译 以下为原文 Hi all. Help me please to save measured data from oscilloscope DSOX4022A to my PC useng LabView. I've found possibility to save data only to USBstick, but I need to save a lot of curves to PC. Thank's in advance |
4个回答
您没有说过您是否曾使用LabView进行任何仪器编程,但如果没有,那么您有机会学习如何编程。
首先,下载X4000编程指南。 这里有一个链接:http://www.keysight.com/main/techSupport.jspx?pid = 2192245& pageMode = OV& cc = US&amp ;lc = eng接下来,您应该考虑下载Command Expert,一个免费的编程 助手,有LabView示例可用。 你可以从这里得到它:http://www.keysight.com/en/pd-2036130/command-expert?nid = -32987.992473& cc = us& pl = eng你应该检查NI网站。 我敢打赌那里也有一些很好的例子。 在这一点上,你应该顺利。 免责声明:为了获得更可靠的响应时间,您应该考虑致电当地的Keysight技术呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 You don't say if you have ever done any instrument programming with LabView, but if not, here's your chance to learn how. First, download the X4000 Programming Guide. There's a link to it here: http://www.keysight.com/main/techSupport.jspx?pid=2192245&pageMode=OV&cc=US&lc=eng Next, you should consider downloading Command Expert, a free programming assistant, that has LabView examples available. You can get it from here: http://www.keysight.com/en/pd-2036130/command-expert?nid=-32987.992473&cc=US&lc=eng You should probably check the NI site. I'll bet there are some good examples there, too. At this point, you should be well on your way. Al Disclaimer: For more reliable response times, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
我对LV的设备有一点经验。
现在我可以用我的范围做一些操作了。 但我找不到任何命令(在程序员指南中)将数据保存到范围直接到PC的文件。 可以将文件从示波器保存到外部USB闪存驱动器或内部存储器。 至于我,这很奇怪,可能是我松了一些东西? 以上来自于谷歌翻译 以下为原文 I have a little experience with devices in LV. Now I can do some operations with my scope. But I can't find any commands(in programmer guide to) to save data to file from scope direct to PC. There is a possibility to save file from scope to external USB flash drive or to internal memory. As for me it's very strange, may be I loose something? |
没有用于将数据直接从示波器保存到PC的直接命令。 范围不知道您正在使用的LAN或USB的另一端是什么,因此它不知道如何启动“文件保存”操作。 如果示波器是基于PC的,并且运行Windows,则可以使用文件共享将文件直接保存到LAN上的远程PC。 您的LabView程序需要告诉范围发送数据,然后您的程序可以使用您想要的任何文件名以您想要的任何格式保存该数据。 免责声明:为了获得更可靠的响应时间,您应该考虑致电当地的Keysight技术呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 There are no direct commands for saving data direct from your scope to a PC. The scope has no idea what's on the other side of the LAN or USB that you are using, so it doesn't know how to initiate a "file save" operation. If the scope was PC-Based, and running Windows, you could use file sharing to save files direct to a remote PC over LAN. Your LabView program needs to tell the scope to send data, then your program can save that data in any format you want, with any filename that you want. Al Disclaimer: For more reliable response times, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
nvywyerwer 发表于 2018-10-10 17:44 谢谢你的算法,我会尽力去做! 以上来自于谷歌翻译 以下为原文 Thank you for algorithm, I'll try to do it! |
只有小组成员才能发言,加入小组>>
1075 浏览 0 评论
2307 浏览 1 评论
2095 浏览 1 评论
1968 浏览 5 评论
2839 浏览 3 评论
843浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
717浏览 0评论
1401浏览 0评论
1075浏览 0评论
GMT+8, 2024-10-2 12:56 , Processed in 1.445164 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
