我有一个16900A,最近变得无法使用。
启动后,“仪器详细信息”显示安装的唯一模块无法正常工作。 模块的初始化状态是“加载后DLL未锁定,DLL失败= 33”。 所以它仍未初始化,LA软件在运行时崩溃了。 如果我卸下模块并启动LA,则软件会指示仪器处于正常工作状态。 我过去曾使用过这种乐器,所以我不确定为什么我现在看到这个错误。 有什么建议么? 以上来自于谷歌翻译 以下为原文 I have a 16900A which recently became unusable. After boot, the "Instrument Details" shows that the only module installed is not working. The module's initialization status is "DLLs not locked after load, failing DLLs = 33". So it remains uninitialized and the LA software crashes when I run it. If I remove the module and boot the LA, the software indicates the instrument is in working order. I have used this instrument in the past, so I'm not sure why I see this error now. Any suggestions? |
3个回答
听起来你有硬件故障。
你没有说你正在使用什么模块,但是你尝试过插入另一个插槽吗? 您是否可以访问其他模块以尝试插入? 免责声明:为了获得更可靠的响应,您应该考虑致电当地的Keysight技术呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 Sounds like you have a HW failure. You don't say what module you are using, but have you tried plugging into a different slot? Do you have access to a different module to try plugging that in? Al Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
这就是我所害怕的。 我尝试了两个不同的插槽,看到同样的问题。 该模块是16911A,不幸的是,我没有其他模块可供我测试。 以上来自于谷歌翻译 以下为原文 That's what I was afraid of. I have tried two different slots and see the same problem. The module is the 16911A and, unfortunately, I don't have another module with which I can test. |
我在工厂与技术支持部门进行了交谈。 卡片变坏的可能性超过90%,需要修理。 很抱歉...... Al免责声明:为了获得更可靠的响应,您应该考虑致电当地的Keysight技术呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 I have spoken with Tech Support at the factory. There is greater than a 90% chance that the card has gone bad, and needs repair. Sorry about that... Al Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1074 浏览 0 评论
2307 浏览 1 评论
2094 浏览 1 评论
1968 浏览 5 评论
2839 浏览 3 评论
843浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
717浏览 0评论
1400浏览 0评论
1075浏览 0评论
GMT+8, 2024-10-2 06:31 , Processed in 1.406736 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
