电子发烧友论坛|
当我的Agilent 16900/16800逻辑分析仪软件(版本03.81.0148)启动时,我会弹出一个弹出窗口。
它说:“无法加载一个对象,因为它在这台机器上不可用。” 我们试着没有运气重新安装软件。 是否取决于未安装RXD软件的外部软件? 它被清除后似乎工作正常,但弹出窗口停止了我们的自动化。 随附的是屏幕截图。 以上来自于谷歌翻译 以下为原文 I am getting a popup when my Agilent 16900/16800 logic analyzer software (version 03.81.0148) is launched. It says: "Could not load an object because it is not available on this machine." We tried re-installing the software without luck. Is it depending on an external piece of software that is not installed from the RXD software install? After it is cleared it seems to work ok, but the popup stops our automation. Attached is the screen shot. 附件
1个回答
看起来微软失去了一些东西,但是,你的洛杉矶FW非常古老。
自您上次更新和更新以来,已有2个主要版本和几个次要版本。 1)确保使用Microsoft Update加载所有最新的修补程序。 确保安装所有.NET包和所有依赖项。 2)获取并安装最新的免费固件更新。 可在www.agilent.com/find/la-sw-download上找到。 如果您有任何可选的FW加载,您也应该下载并安装它。 3)如果您仍有问题,请告诉我们。 人 以上来自于谷歌翻译 以下为原文 It looks like Microsoft lost something, but also, your LA FW is VERY old. There have been 2 major release and several minor releases since you last did and update. 1) Make sure that all of the latest patches are loaded, using Microsoft Update. Make sure you install all of the .NET packages and all dependencies. 2) Get and install the latest free FW update. It is available at www.agilent.com/find/la-sw-download. If you have any optional FW loaded, you should download and install that, as well. 3) Let us know if you still have problems. Al |
只有小组成员才能发言,加入小组>>
290 浏览 0 评论
1871 浏览 0 评论
2757 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
290浏览 0评论
/9
GMT+8, 2025-12-14 12:49 , Processed in 0.623913 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
476
