嗨,
我们使用STEVAL-IHM023V3和STM32VLD发现板进行测试,我们可以毫无问题地运行电机。但是,当我们开始评估是否可以将STEVAL-IHM023V3与STM32F3xx板一起用于测试Motor Profiler功能时,我们发现STMCWB不支持此功能。 STMCWB仅支持MB459,STEVAL-IHM028V2和STEVAL-IHM025V1的电机分析器。然后我们研究了IHM028V2和IHM025V1的原理图,并将它们与IHM023V3的原理图进行了比较。我们找不到任何理由为什么STMCWB不支持IHM023V3的Motor Profiler。我可以知道有没有办法将IHM023V3用于Motor Profiler? #motor-profiler#steval-ihm023v3 以上来自于谷歌翻译 以下为原文 Hi, We are using the STEVAL-IHM023V3 with the STM32VLDiscovery board for testing and we are able to run the motor without any problem. However, when we start to evaluate if we can use the STEVAL-IHM023V3 with a STM32F3xx board for testing the Motor Profiler feature, we found that the STMCWB doesn't support this. The STMCWB supports Motor Profiler for MB459, STEVAL-IHM028V2 and STEVAL-IHM025V1 only. Then we have studied the schematics of the IHM028V2 and IHM025V1 and compare these with the schematics of the IHM023V3. We cannot find any reason why STMCWB does not support Motor Profiler for IHM023V3. May I know that is there a way we can use IHM023V3 for Motor Profiler? #motor-profiler #steval-ihm023v3 |
4个回答
再见
我认为这可以通过一种解决方法来完成,使用STEVAL-IHM025V1(与STEVAL-IHM023V3非常相似)启动一个新项目,并根据STEVAL-IHM023V3的设置手动修改功率级。 您可以使用STEVAL-IHM023V3打开两个STM32电机控制工作台实例,另一个使用基于STEVAL-IHM025V1的新项目进入功率级,并将每个值从一个项目复制到另一个项目。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao I think that this can be done with a workaround, starting a new project with STEVAL-IHM025V1 (that is very similar to the STEVAL-IHM023V3) and modify manually the power stage according the setting of STEVAL-IHM023V3. You can open two instance of STM32 Motor Control Workbench one with the STEVAL-IHM023V3 and the other with a new project based on STEVAL-IHM025V1 go in the power stage and copy each value from one to the other project. Ciao Gigi |
可以为STEVAL-IHM039V1做类似的事吗?它使用支持的处理器,但未列为与SDK中的电机配置文件兼容。
以上来自于谷歌翻译 以下为原文 Could a similar thing be done for the STEVAL-IHM039V1? It is using a supported processor, but isn't listed as compatible with the Motor Profile in the SDK. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2730 浏览 1 评论
3239 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1808 浏览 1 评论
3647 浏览 6 评论
6035 浏览 21 评论
1339浏览 4评论
198浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
442浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
273浏览 2评论
GMT+8, 2024-12-23 04:40 , Processed in 1.215673 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
