我正在通过I2C读取数据。执行的计算是正确的(将高字节和低字节转换为12位值,并使用195mg /位将数据转换为+/- 400g级别的标度。)。
在所有三个轴上都有大约+/- 10g的噪音。因此,当设备保持静止时,图形将始终波动。 忽略+/- 10g噪声,X轴和Y轴数据都很好。但是Z轴数据总是偏移大约8g。因此,当设备直立并保持静止时,Z轴数据平均为8g,必须为1g。因此,Z轴的曲线图将在8g处波动。 以上来自于谷歌翻译 以下为原文 I am reading data through I2C. The calculations performed are correct (Converting high and low bytes into a 12 bit value and using 195mg/digit to convert data into scales of +/- 400g level.). There is a noise of about +/-10g in all the three axis. So the graph will always be fluctuating when the device is kept still. Neglecting the +/- 10g noise, the X and Y axis data are fine. But Z axis data is always shifted by about 8g. So the Z axis data has an average of 8g, when the device is upright and kept still, which had to be 1g. So the graph of Z axis will be fluctuating at 8g with. |
4个回答
你能否分享你的程序,将低字节和高字节转换成加速度值?噪音对我来说太高了。
在400 g满量程时,偏移量可能非常高,您可以使用高通滤波器将其移除或在微控制器中进行校准。 以上来自于谷歌翻译 以下为原文 Can you please share your procedure to convert the low and high byte into acceleration value? The noise seems to me too high. At the 400 g full scale the offset can be quite high, you can remove it by using high-pass filter or make a calibration in you micro-controller. |
合并两个字节。除以4,因为数据是12位。乘以0.195。即合并并乘以0.04875。是的,先生?
以上来自于谷歌翻译 以下为原文 Merge two bytes. Divide by 4 since data is 12 bits. multiply by 0.195. i.e merge and multiply by 0.04875. Is it right sir? |
这是不正确的。
由于数据是16位寄存器中的12位,因此必须将数据右移4或除以16。 以上来自于谷歌翻译 以下为原文 It is not correct. Since the data are 12 bits in 16 bits register, you have to shift right the data by 4 or divide by 16. |
对不起这是我的错。计算似乎是正确的。我的意思是,我实际上正确地移动了4.通过使用过滤器解决了问题。谢谢你的解决方案,先生。过滤器删除了偏移量。噪音减少了,现在可以忽略不计!
以上来自于谷歌翻译 以下为原文 Sorry, my bad. The calculations seemed to be right. I mean, I was actually right shifting by 4. The problem got solved by using the filter. Thanks for the solution, Sir. The filter removed the offset. The noise has reduced and its negligible now! |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 10:01 , Processed in 0.688422 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
407
