电子发烧友论坛|
你好
我正在尝试布线spartan6设计。我有一个MPMC模块,它实现了一个运行速度为400 mhz的LPDDR内存。我使用时钟发生器内核将400Mhz和400Mhz 180相位馈送到MPMC。 发电机配置菜单我可以选择使用缓冲区。我现在不明白.. 当我选择在clkout0和clkout1输出上有缓冲区时,映射器会抱怨并要求我用UCF中的CONSTRAIN来纠正它。 ../clock_generator0/PLL_CLOCKOUT0_BUFG_INST.O“CLOCK DEDICATED ROUTE FALSE; ./clock_generator0/PLL_CLOCKOUT1_BUFG_INST.O“CLOCK DEDICATED ROUTE FALSE; 好吧,在我这样做后,MAPPER继续前进并且路线或多或少。 现在如果我在时钟发生器菜单上直接进行更改(NO BUFFER)..我删除了UCF中的先前约束 Mapper失败它告诉我像PLL_BUFF没有被放置的东西。我怎么能放置那些缓冲区。 我以为 那些是我可以在时钟发生器上选择的缓冲器!! 请帮忙..! 以上来自于谷歌翻译 以下为原文 Hi I'm in the process of trying to route a spartan6 design .I have a MPMC module that implements a LPDDR memory running at 400 mhz .I use a clock generator core to feed the 400Mhz and 400Mhz 180 phase to the MPMC .In the clock generator configuration menu i can choose to use a buffer or not .Well I dont understand NOW .. When i choose to have buffers on clkout0 and clkout1 outputs the mapper complains and asks me to correct it with a CONSTRAIN in the UCF .. ../clock_generator0/PLL_CLOCKOUT0_BUFG_INST.O" CLOCK DEDICATED ROUTE FALSE ; ./clock_generator0/PLL_CLOCKOUT1_BUFG_INST.O" CLOCK DEDICATED ROUTE FALSE ; Well after i do that the MAPPER goes ahead and routes more or less . Now if i make the changes drectly on the clock generator menu ( NO BUFFER) .. I remove the previous constrains in UCF The Mapper fails it tells me sometthing like the PLL_BUFF are not placed .How can i place those buffers . I thought that those were the buffers i could select on the Clock GENERATOR !! Some help please ..! |
1个回答
这是与您在另一个帖子中发布的thePlace:1114错误相同的问题吗?
如果是这样,请参阅我的回复。 如果没有,您需要在我们帮助您之前向我们提供完整的错误消息。 以上来自于谷歌翻译 以下为原文 Is this the same issue as the Place:1114 error that you posted about in another thread? If so, see my response there. If not you'll need to give us the complete error message before we can help you. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 23:57 , Processed in 0.477722 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1641
