扫一扫,分享给好友
necleo f411RE的板子使用std库点灯程序都不正常,把gpio初始化的代码改成HAL的就正常了,f411re用不了std库吗?是necleo板子的原因还是这个芯片的原因?
5个回答
求救啊顶顶顶顶顶顶!
建议你把用标准库和HAL库写的代码贴出来看看!
HAL库封装的比较完整,标准库需要自己配置的比较多,可能是少了某项吧。你在仔细看看
void HAL_GPIO_Init(GPIO_TypeDef *GPIOx, GPIO_InitTypeDef *GPIO_Init)
{ uint32_t position; uint32_t ioposition = 0x00; uint32_t iocurrent = 0x00; uint32_t temp = 0x00; /* Check the parameters */ assert_param(IS_GPIO_ALL_INSTANCE(GPIOx)); assert_param(IS_GPIO_PIN(GPIO_Init->Pin)); assert_param(IS_GPIO_MODE(GPIO_Init->Mode)); assert_param(IS_GPIO_PULL(GPIO_Init->Pull)); /* Configure the port pins */ for(position = 0; position < GPIO_NUMBER; position++) { /* Get the IO position */ ioposition = ((uint32_t)0x01) << position; /* Get the current IO position */ iocurrent = (uint32_t)(GPIO_Init->Pin) & ioposition; if(iocurrent == ioposition) { /*--------------------- GPIO Mode Configuration ------------------------*/ /* In case of Alternate function mode selection */ if((GPIO_Init->Mode == GPIO_MODE_AF_PP) || (GPIO_Init->Mode == GPIO_MODE_AF_OD)) { /* Check the Alternate function parameter */ assert_param(IS_GPIO_AF(GPIO_Init->Alternate)); /* Configure Alternate function mapped with the current IO */ temp = GPIOx->AFR[position >> 3]; temp &= ~((uint32_t)0xF << ((uint32_t)(position & (uint32_t)0x07) * 4)) ; temp |= ((uint32_t)(GPIO_Init->Alternate) << (((uint32_t)position & (uint32_t)0x07) * 4)); GPIOx->AFR[position >> 3] = temp; } /* Configure IO Direction mode (Input, Output, Alternate or Analog) */ temp = GPIOx->MODER; temp &= ~(GPIO_MODER_MODER0 << (position * 2)); temp |= ((GPIO_Init->Mode & GPIO_MODE) << (position * 2)); GPIOx->MODER = temp; /* In case of Output or Alternate function mode selection */ if((GPIO_Init->Mode == GPIO_MODE_OUTPUT_PP) || (GPIO_Init->Mode == GPIO_MODE_AF_PP) || (GPIO_Init->Mode == GPIO_MODE_OUTPUT_OD) || (GPIO_Init->Mode == GPIO_MODE_AF_OD)) { /* Check the Speed parameter */ assert_param(IS_GPIO_SPEED(GPIO_Init->Speed)); /* Configure the IO Speed */ temp = GPIOx->OSPEEDR; temp &= ~(GPIO_OSPEEDER_OSPEEDR0 << (position * 2)); temp |= (GPIO_Init->Speed << (position * 2)); GPIOx->OSPEEDR = temp; /* Configure the IO Output Type */ temp = GPIOx->OTYPER; temp &= ~(GPIO_OTYPER_OT_0 << position) ; temp |= (((GPIO_Init->Mode & GPIO_OUTPUT_TYPE) >> 4) << position); GPIOx->OTYPER = temp; } /* Activate the Pull-up or Pull down resistor for the current IO */ temp = GPIOx->PUPDR; temp &= ~(GPIO_PUPDR_PUPDR0 << (position * 2)); temp |= ((GPIO_Init->Pull) << (position * 2)); GPIOx->PUPDR = temp; /*--------------------- EXTI Mode Configuration ------------------------*/ /* Configure the External Interrupt or event for the current IO */ if((GPIO_Init->Mode & EXTI_MODE) == EXTI_MODE) { /* Enable SYSCFG Clock */ __HAL_RCC_SYSCFG_CLK_ENABLE(); temp = SYSCFG->EXTICR[position >> 2]; temp &= ~(((uint32_t)0x0F) << (4 * (position & 0x03))); temp |= ((uint32_t)(GPIO_GET_INDEX(GPIOx)) << (4 * (position & 0x03))); SYSCFG->EXTICR[position >> 2] = temp; /* Clear EXTI line configuration */ temp = EXTI->IMR; temp &= ~((uint32_t)iocurrent); if((GPIO_Init->Mode & GPIO_MODE_IT) == GPIO_MODE_IT) { temp |= iocurrent; } EXTI->IMR = temp; temp = EXTI->EMR; temp &= ~((uint32_t)iocurrent); if((GPIO_Init->Mode & GPIO_MODE_EVT) == GPIO_MODE_EVT) { temp |= iocurrent; } EXTI->EMR = temp; /* Clear Rising Falling edge configuration */ temp = EXTI->RTSR; temp &= ~((uint32_t)iocurrent); if((GPIO_Init->Mode & RISING_EDGE) == RISING_EDGE) { temp |= iocurrent; } EXTI->RTSR = temp; temp = EXTI->FTSR; temp &= ~((uint32_t)iocurrent); if((GPIO_Init->Mode & FALLING_EDGE) == FALLING_EDGE) { temp |= iocurrent; } EXTI->FTSR = temp; } } } } //////////////////////////////////////////////////////////////////////////////// void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct) { uint32_t pinpos = 0x00, pos = 0x00 , currentpin = 0x00; /* Check the parameters */ assert_param(IS_GPIO_ALL_PERIPH(GPIOx)); assert_param(IS_GPIO_PIN(GPIO_InitStruct->GPIO_Pin)); assert_param(IS_GPIO_MODE(GPIO_InitStruct->GPIO_Mode)); assert_param(IS_GPIO_PUPD(GPIO_InitStruct->GPIO_PuPd)); /* ------------------------- Configure the port pins ---------------- */ /*-- GPIO Mode Configuration --*/ for (pinpos = 0x00; pinpos < 0x10; pinpos++) { pos = ((uint32_t)0x01) << pinpos; /* Get the port pins position */ currentpin = (GPIO_InitStruct->GPIO_Pin) & pos; if (currentpin == pos) { GPIOx->MODER &= ~(GPIO_MODER_MODER0 << (pinpos * 2)); GPIOx->MODER |= (((uint32_t)GPIO_InitStruct->GPIO_Mode) << (pinpos * 2)); if ((GPIO_InitStruct->GPIO_Mode == GPIO_Mode_OUT) || (GPIO_InitStruct->GPIO_Mode == GPIO_Mode_AF)) { /* Check Speed mode parameters */ assert_param(IS_GPIO_SPEED(GPIO_InitStruct->GPIO_Speed)); /* Speed mode configuration */ GPIOx->OSPEEDR &= ~(GPIO_OSPEEDER_OSPEEDR0 << (pinpos * 2)); GPIOx->OSPEEDR |= ((uint32_t)(GPIO_InitStruct->GPIO_Speed) << (pinpos * 2)); /* Check Output mode parameters */ assert_param(IS_GPIO_OTYPE(GPIO_InitStruct->GPIO_OType)); /* Output mode configuration*/ GPIOx->OTYPER &= ~((GPIO_OTYPER_OT_0) << ((uint16_t)pinpos)) ; GPIOx->OTYPER |= (uint16_t)(((uint16_t)GPIO_InitStruct->GPIO_OType) << ((uint16_t)pinpos)); } /* Pull-up Pull down resistor configuration*/ GPIOx->PUPDR &= ~(GPIO_PUPDR_PUPDR0 << ((uint16_t)pinpos * 2)); GPIOx->PUPDR |= (((uint32_t)GPIO_InitStruct->GPIO_PuPd) << (pinpos * 2)); } } } ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// 这两个函数的问题,用第一个初始化是正常的,第二个就不行。。。 |
这两个函数有什么不同呢???
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2797 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2403 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2276 浏览 0 评论
2388 浏览 1 评论
1637 浏览 1 评论
/9
GMT+8, 2025-12-2 02:44 , Processed in 0.667264 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2575
