电子发烧友论坛|
HI:当我调试UVC AN779代码时,我遇到了一个问题。当我关闭AMCAP时,我收到了来自主机的一组特性请求。一旦我收到了SET功能内容,视频流接口就被远程唤醒了,而我不能使用AMCAP,你必须对USB 3设备进行复制。为什么会这样?
以上来自于百度翻译 以下为原文 Hi: When I debugged the UVC AN75779 code, I encountered a problem. When I turned off the AMCAP, I received a SET FEATURE request from the host. Once I received the SET FEATURE content, the video streaming interface was remotely awake, and I could not With AMCAP, you must replug the USB 3.0 device. Why is this? |
7个回答
HI:这是USB跟踪,每次设置的功能发布(内容是:远程唤醒)和AMCAP再次打开,视频流将崩溃。我怀疑它是在U2/U3模式。这怎么解决?设备是否阻塞U2/U3或远程唤醒处理代码,如果将其添加到远程唤醒处理代码中,唤醒进程是什么?有什么具体的文件吗?
以上来自于百度翻译 以下为原文 Hi:This is the u*** trace, Every time SET FEATURE is issued (content is: remote wake-up) and AMCAP is turned on again, the video stream will crash. I suspect that it is in U2/U3 mode. How can this be solved? Is the device blocking the U2/U3 or remote wake-up processing code, and if it is added to the remote wake-up processing code, what is the wakeup process? Is there any specific documentation? |
wu58518 发表于 2018-10-1 16:20 禁用Low Power Entry(U0≫U1/U2/U3)使用CYU3PUBLPMPL一旦应用程序是活动的。 这不允许链路进入低功率模式。 在AN7799中引用CYFXUVCPLAPNSTART。 通过描述符启用远程唤醒支持吗? 共享描述符文件。 以上来自于百度翻译 以下为原文 Disable the Low Power Entry (U0 -> U1/U2/U3) using CyU3PU***LPMDisable once the application is active. This does not allow the link to go to low power mode. Refer CyFxUvcApplnStart in AN75779. Did you enable the remote wake up support through the descriptors? Share the descriptor file. |
你好:我用超高速USB连接!
CYFXVCDC.C.ZIP 6.4 K 以上来自于百度翻译 以下为原文 Hi: i use the super speed u*** link! tank you very much!
嗨,作为下图,我还没有启用远程唤醒,但我不知道为什么我收到SET功能(01 03 00 00 02 01 00 00)
一旦收到设置的特性,AMCAP将打开故障! 以上来自于百度翻译 以下为原文 Hi; As the below picture,I have not enabled the remote wake but i do not know why i received set feature (01 03 00 00 02 01 00 00) and once receive the set feature, amcap will open failture! |
我读了USB协议集的这一内容的部分内容,01、03、00、00、02、01、00、00的意识是启用接口1的远程唤醒功能。
以上来自于百度翻译 以下为原文 I read the USB protocol SET FEATURE part of this content, 01 03 00 00 02 01 00 00 awareness is to enable the remote wake-up function of interface 1 |
我们会尝试重新制作这个问题并让你知道。 上传你的固件在这里。 如果你不能上传整个固件,只需附加UVC.C文件即可。 以上来自于百度翻译 以下为原文 We will try to re-produce the issue and let you know. Upload your firmware here. If you can not upload the entire firmware, just attach uvc.c file. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 20:36 , Processed in 0.905075 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1799
