你好,
我看过您的开发人员Webimar:几天前将AI集成到您的加速云应用程序中。 我试图重做视频中显示的张量流程示例,但似乎AWS市场中提供的最新AMI Xilinx ML Suite 18-04-02与视频中的文件不同。 例如,在tensorflow docker中,我找不到文件夹/ xlnx / xfdnn_tools / compile中的4 run_caffe _ * .sh和run_tf _ *。sh(如视频中26:22所列)。 此外,我尝试按照编译器教程但在步骤6,AMI没有.py但是他们编译的版本.pyc.I试图运行步骤6 cmd但是用.pyc替换.py,我得到一个错误 。 我没有做任何特别的事情,期望用AMI版本18.04.02创建实例,并尝试按照上面的教程。 请你仔细检查AMI,详细说明可以做什么? 谢谢你的帮助。 安东尼。 以上来自于谷歌翻译 以下为原文 Hello, I watched your Developer Webimar: Integrating AI into Your Accelerated Cloud Applications some days ago. I tried to redo the tensorflow exemple showed in the video, but it seems the latest AMI Xilinx ML Suite 18-04-02 available in the AWS marketplace does not have the same files as in the video. For instance, inside the tensorflow docker, I can't find the 4 run_caffe_*.sh and run_tf_*.sh in the folder /xlnx/xfdnn_tools/compile (as listed at 26:22 in the video). Also, I tried to follow the compiler tutorial but at step 6, the AMI doesn't have the .py but their compiled version .pyc. I tried to run the step 6 cmd but replacing the .py by .pyc, and I get an error. I haven't done anything in particular, expect creating the instance with AMI version 18.04.02, and tried to follow the above tutorial. Could you please double check the AMI, and detailed what is possible to do? Thanks for your help. Anthony. |
2个回答
你好@ ahockkoon
请参考下面的Git,看看能否从README / docs中找到一些相关的指针 https://github.com/aws/aws-fpga 对于AWS F1相关查询,您可以在此处发布: https://forums.aws.amazon.com/forum.jspa?forumID=243&start=0 问候, 肖恩 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi @ahockkoon Please refer following Git and see if can find some relevant pointers from README/docs https://github.com/aws/aws-fpga For AWS F1 related query, you can post here: https://forums.aws.amazon.com/forum.jspa?forumID=243&start=0 Regards, Sean ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
你好,
我不太关注,Xilinx ML套件是Xilinx提供的AMI,所以你们。 您的一些教程://github.com/Xilinx/ML-Suite对您最新的AMI中提供的内容似乎不准确。 一些其他上下文链接: https://www.xilinx.com/applications/megatrends/machine-learning.html https://aws.amazon.com/marketplace/pp/B077FM2JNS 安东尼。 以上来自于谷歌翻译 以下为原文 Hello, I'm not sure to follow, the Xilinx ML-suite is an AMI provided by Xilinx, so you guys. There are the some of your tutorial https://github.com/Xilinx/ML-Suite that do not seem to be accurate with what is provided in your latest AMI. Some other context links: https://www.xilinx.com/applications/megatrends/machine-learning.html https://aws.amazon.com/marketplace/pp/B077FM2JNS Anthony. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 22:18 , Processed in 0.704453 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3253
