电子发烧友论坛|
嗨,
我们运行了以下两个示例,其中1个通过,1个失败。 传递示例 - cl_hello_world(opencl示例),我们创建了一个DCP文件并将其用于我们的应用程序 失败的例子 - ml-suite / image_classification,这里我们面临运行应用程序的问题。 我们收到以下错误 - xclProbe找到1个带有xocl驱动程序运行的FPGA插槽ERROR:加载映像失败.ERROR:睡眠直到加载失败。警告:AwsXcl - 无法打开userPF:/ dev / dri / renderD15596ERROR AwsXcl:PCI内核条连接失败,插槽#0警告:AwsXcl isGood: 内核,全球和 mgmt bar是:ffffffff,ffffffff,ffffffffWARNING:xclOpen句柄检查失败[0]用户:0x1042:0x7:[???:??:0]设备[0] .user_instance:0ERROR:加载图像失败.ERROR:睡眠直到 加载失败。警告:AwsXcl - 无法打开userPF:/ dev / dri / renderD0ERROR AwsXcl:插槽#0的PCI内核栏附加失败警告:AwsXcl isGood:kernel,global& mgmt bar是:ffffffff,ffffffff,ffffffff 我们不是在这个例子中创建DCP文件,我们不确定示例是否完整!! 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, We ran the following 2 examples, in which 1 passed and 1 failed. Passing example - cl_hello_world (opencl example), We have created a DCP file and used that for our application Failing example - ml-suite/image_classification, Here we are facing issue in running the application. We are getting the following error - xclProbe found 1 FPGA slots with xocl driver running ERROR: Load image failed. ERROR: Sleep until load failed. WARNING: AwsXcl - Cannot open userPF: /dev/dri/renderD15596 ERROR AwsXcl: PCI kernel bar attach failed for slot# 0 WARNING: AwsXcl isGood: kernel, global & mgmt bar are: ffffffff, ffffffff, ffffffff WARNING: xclOpen Handle check failed [0]user:0x1042:0x7:[???:??:0] device[0].user_instance : 0 ERROR: Load image failed. ERROR: Sleep until load failed. WARNING: AwsXcl - Cannot open userPF: /dev/dri/renderD0 ERROR AwsXcl: PCI kernel bar attach failed for slot# 0 WARNING: AwsXcl isGood: kernel, global & mgmt bar are: ffffffff, ffffffff, ffffffff We are not creating the DCP file in this example, We are not sure whether the example is complete or not!! Thanks. |
1个回答
你好
从日志信息中,示例未完成,它在开始时失败。 FPGA用户PF驱动程序有问题。 请检查设备驱动程序是否在机器中正确安装。 你能检查一下你正在使用的AMI吗? 你最好试试这个例子 Xilinx ML Suite 18.04.02-07173bb3-d69b-4f6c-8422-d57479542ba9-ami-f50ba988.4 https://aws.amazon.com/marketplace/pp/B077FM2JNS 谢谢 以上来自于谷歌翻译 以下为原文 Hi From the log info, the example is not complete, it fail in the beginning. The FPGA user PF driver have problem. please check if the the device driver is installed correctly in the machine. could you please check what the AMI your are using? you'd better try the example in Xilinx ML Suite 18.04.02-07173bb3-d69b-4f6c-8422-d57479542ba9-ami-f50ba988.4 https://aws.amazon.com/marketplace/pp/B077FM2JNS Thanks |
只有小组成员才能发言,加入小组>>
3137 浏览 7 评论
3433 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2895 浏览 9 评论
4094 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3079 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1353浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1191浏览 1评论
/9
GMT+8, 2025-12-9 18:05 , Processed in 0.650649 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3260
