时间和温度的时钟稳定性没有数据。这些将影响采样率时间。例如,如果加速度计DOR是100Hz,则可以预期到什么样的扩散。我认为在所有三种传感器类型中,从开始转换到中断的时间,时间大致是DOR的倒数。这对于磁强计来说是真的,我假设设置/复位在每个采样期间都需要一个固定的时间,而不管DOR如何。我想要有一个100Hz的固定数据更新率,从主处理器生成,有没有人做过这类事情,或者你只是自由运行LSM9DS0,并接受编程到它的速率?我接受我只能以我要求的速率从磁力计获得50Hz的有效频率。我是这个设备的新手,以前使用过模拟部件,我可以更好地控制采样率。
任何评论将不胜感激, 以上来自于谷歌翻译 以下为原文 There are no figures for clock stability over time and temperature. These are going to effect the sample rate times. For example, if the accelerometer DOR is 100Hz, what spread can be expected. I take it that in all of the three sensors types, that the time from commencing a conversion to the Interrupt, the time is roughly the reciprocal of the DOR. Is this true for the Magnetometer, where I assume the Set/Reset takes a fixed time during every sample, irrespective of the DOR. I am wanting to have a fixed data update rate of 100Hz, generated from the host processor, has anyone done this sort of thing, or are you just free running the LSM9DS0, and accepting the rate programmed into it? I accept that I will only get an effective 50Hz from the magnetometer at the rate I require. I am new to this device, have used analogue parts previously, where I could get better control of the sampling rate. Any comments would be much appreciated, |
3个回答
你好,
我目前正在验证是否对时钟和温度的时钟漂移进行了任何研究,这不是您通常应该关注的问题。 如果您有任何其他问题或需要进一步支持您的申请,请告诉我。 谢谢, 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello, I am currently verifying if it was done any study with regards to the clock drift over time and temperature, this is not an issue that you normally should be concerned with. If you have any other questions or need further support on your application, please let me know. Thank you, Thiago Reis |
谢谢,不知道什么技术用于计时。
以上来自于谷歌翻译 以下为原文 Thanks, wasn't sure what technology was used for clocking. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2746 浏览 1 评论
3244 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
449浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
276浏览 2评论
GMT+8, 2024-12-28 15:18 , Processed in 1.193173 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
