电子发烧友论坛|
我用CLA执行两个任务,task8和task1,task8使用软件触发,task1使用ADCINT1触发,现在问题是,我用软件触发task8之后,task8无法执行,而只有task1才能被中断触发。
EALLOW; // Copy the CLA program code from its load address to the CLA program memory // Once done, assign the program memory to the CLA // Make sure there are at least two SYSCLKOUT cycles between assigning // the memory to the CLA and when an interrupt comes in // Call this function even if Load and Run address is the same! // MemCopy(&Cla1funcsLoadStart, &Cla1funcsLoadEnd, &Cla1funcsRunStart); memcpy(&Cla1funcsRunStart, &Cla1funcsLoadStart, (Uint32) &Cla1funcsLoadSize); asm(" RPT #3 || NOP"); Cla1Regs.MMEMCFG.bit.PROGE = 1; // Configure the RAM as CLA program memory // Cla1Regs.MMEMCFG.bit.RAM0E = 1; // configure RAM L1, F28035 as CLA Data memory 0 // Cla1Regs.MMEMCFG.bit.RAM1E = 1; // Configure RAM L2, F28035 as CLA data memory 1 // Symbols used in calculation are defined in CLA_Shared.h file Cla1Regs.MVECT1 = ((Uint16) Cla1Task1 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT2 = ((Uint16) Cla1Task2 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT3 = ((Uint16) Cla1Task3 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT4 = ((Uint16) Cla1Task4 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT5 = ((Uint16) Cla1Task5 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT6 = ((Uint16) Cla1Task6 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT7 = ((Uint16) Cla1Task7 - (Uint16) &Cla1Prog_Start); Cla1Regs.MVECT8 = ((Uint16) Cla1Task8 - (Uint16) &Cla1Prog_Start); // Enable the IACK instruction to start a task (software task triggering) Cla1Regs.MCTL.bit.IACKE = 1; Cla1Regs.MPISRCSEL1.bit.PERINT1SEL = 0; // 0=ADCINT1 1=none 2=EPWM1INT // Enable the CLA interrupt 1 (Allow CLA to be interrupted) Cla1Regs.MIER.all = M_INT1; // Configure the interrupt that would occur each control cycles asm(" RPT #3 || NOP"); // No need to wait, the task will finish by the time // we configure the ePWM and ADC modules Cla1ForceTask8(); EDIS; ] 我认为是我的cmd有问题,我觉得源代码并没有问题的,请工程师们帮我分析下原因。 |
相关推荐 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 05:15 , Processed in 0.787229 second(s), Total 46, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1781
