电子发烧友论坛扫一扫,分享给好友
你好
我尝试在无环回模式下测量IBERT。不幸的是,工具在此模式下显示NO LINK。另一方面,在近端PCS和近端PMA模式的情况下,LINK正常。 有人知道为什么会出现这个问题吗?还有人能告诉我如何解决这个问题吗? 我在下面显示我的硬件状况。 Rx板:ZC706Tx板:我们的原板。我使用FMC HPC连接器作为收发器接口。参考时钟由我们的原板提供。参考时钟频率为100MHz。收发器数据速率为2.0Gbps。 当我通过使用收发器IP从我们的原始板接收串行数据时,接收的数据是正确的。但是我无法测量IBERT。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi I try to measure IBERT in none loopback mode. Unfortunately, tool shows NO LINK in this mode. On the other hands, in case of Near end PCS and Near end PMA mode, LINK is OK. Does someone knows why this problem occur? Also could someone tell me how to solve this problem? I show my hardware condition in following. Rx board : ZC706 Tx board : our original board. I use FMC HPC connector for transceiver interface. Reference clock is provided from our original board. The frequency of reference clock is 100MHz. Transceiver data rate is 2.0Gbps. When I receive serial data from our original board by using transceiver IP, the received data is correct. However I can not measure IBERT. Thank you. |
3个回答
嗨,
IBERT期望PRBS序列作为检测链路的数据。 你的TX提供这个吗? 最好的祝福, 埃里克 -------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, IBERT is expecting a PRBS sequence as data to detect a link. Is your TX providing this? Best regards, Erik ------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------View solution in original post |
嗨,
IBERT期望PRBS序列作为检测链路的数据。 你的TX提供这个吗? 最好的祝福, 埃里克 -------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hi, IBERT is expecting a PRBS sequence as data to detect a link. Is your TX providing this? Best regards, Erik ------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
你好@ eschidl
谢谢您的回复。 我明白你说了什么。 我们的原始板只提供随机数据而不是PRBS。 另外我注意到如果工具显示NO LINK,我可以做EYESCANeven。 所以现在我的问题解决了。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi @eschidl Thank you for your reply. I understood what you said. Our original board just provide random data not PRBS. Also I have noticed that I can do EYESCAN even if tool shows NO LINK. So now my problem is solved. Thank you. |
只有小组成员才能发言,加入小组>>
3142 浏览 7 评论
3436 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3082 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1197浏览 1评论
/9
GMT+8, 2025-12-12 19:57 , Processed in 0.578032 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2300
