我使用的是PIC24FJ256DA210开发板,真正的3.2英寸LCD插入其中。我有一个运行良好的项目,但我不得不替换真正的LCD。当我开始通过虚拟图形设计开发人员生成的代码时,屏幕是空白的。没有文字,所以我触摸了屏幕。校准功能把一个红点放在屏幕上,但是我没有办法知道它想要触摸的位置。我触摸了其他3个角落,但它们显然不是代码寻找的角落,因为现在当我运行项目时,触摸位置是错误的。我试图连接16KB触摸屏驱动程序(DrvouTouChyScult.C在2017 MLA),但文件不断被删除。
C(15.60 KB)下载43次 以上来自于百度翻译 以下为原文 I'm using the pic24fj256da210 development board with the Truly 3.2" LCD plugged into it. I have a project that was running fine but I had to replace the Truly LCD. When I started code that I generated through the Virtual Graphics Design Developer the screen was blank. There was no writing so I touched the screen. The calibration function put a red dot on the screen but I had no way to know where it wanted the touch to be. I touched the other 3 corners but they clearly weren't the corners the code was looking for because now when I run the project the touch locations are wrong. I've tried to attach the 16kb touch screen driver (drv_touch_screen.c in the 2017 mla) but the file keeps getting deleted. Attachment(s) drv_touch_screen.c (15.60 KB) - downloaded 29 times drv_touch_screen.c (15.60 KB) - downloaded 43 times |
1个回答
我发现我可以在触摸屏上握住手指来重新校准电源。
以上来自于百度翻译 以下为原文 I figured out that I can recalibrate by holding my finger on the touch screen on power up |
只有小组成员才能发言,加入小组>>
5104 浏览 9 评论
1965 浏览 8 评论
1904 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3134 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2202 浏览 5 评论
675浏览 1评论
548浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
422浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
573浏览 0评论
471浏览 0评论
GMT+8, 2024-10-20 06:01 , Processed in 1.192675 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
