我用PIC24FJ2156DA210开发板做了一个真正的3.2“240×320触摸屏”的设计。我问Microchip的来源,但他们给我的来源没有携带它。有人做了一个使用3.2或3.5触摸显示器的设计?谢谢
以上来自于百度翻译 以下为原文 I did a design using the pic24fj2156da210 development board with the Truly 3.2" 240 x 320 touch screen. I asked Microchip for a source but the source they gave me does not carry it. Has anyone done a design using a 3.2" or 3.5" touch display? Thanks |
12个回答
2010-2013年微芯片库中的遥控器应用程序有这样一个LCD的代码和PIC:你看过了吗?
以上来自于百度翻译 以下为原文 The RemoteControl App inside Microchip libraries from 2010-2013 has code for such a LCD along with that PIC: did you rake a look at them? |
不,我的代码工作。现在我需要为我的应用程序触摸显示。我已经完成了开发板,并希望迁移到一个独立的产品。
以上来自于百度翻译 以下为原文 No, I have my code working. Now I need to get the touch display for my application. I'm done with the development board and want to migrate to a stand-alone product. |
许多公司制作了3.2个“显示器”:HTTP://OrthDistPo.COM/CSTN-TFT-LCDS.HTMLuness,您希望使用的是一个精确的芯片。
以上来自于百度翻译 以下为原文 A Lot of Companies make 3.2" Displays; http://orientdisplay.com/cstn-tft-lcds.html Unless you want the exact one Microchip used. |
准备好让你的头脑发亮。ST7920i做了单声道显示,并编写了一些非常好的位图映射/剪辑功能。20×14×12空间入侵者以很快的速度移动。没有愚蠢的像素写。关键是从显示器读取字节,没有任何缓冲或固定延迟。在4bit并行模式下使用RD/WR比1024字节缓冲器和固定时间快第三倍。8bit几乎翻倍。ST7920可以处理2个时钟@ 40MHz fsiy的E/PLOPE时间。将此增加到4速度。在LCD上进行了处理,之后它慢下来了。我现在用半SPI测试,因为它不能发送,2个小写需要分开发送。没有R/W,它将不能击败并行。ILI9499已经查看了彩色/触摸屏数据表,它是最复杂的数据表之一。EI9988-初步的DS2V090。谷歌,333页,不包括触摸屏接口。SPI和DMA.320×256像素*24位。用于完整显示的245760字节。
以上来自于百度翻译 以下为原文 Prepare to have your mind blown. ST7920 I did the mono display and wrote some really good bitmapping/clipping functions. 20 14*12 space invaders moving at a fast rate. No silly pixel writes. The key to that is reading bytes from the display without any buffer or fixed delays. Using rd/wr in 4bit parallel mode is a third times quicker than a 1024 byte buffer and a fixed time. 8bit nearly doubles that. The st7920 can handle an E/strope time of 2 clocks @ 40MHz fcy. Increasing this to 4 speeds up processing on the lcd, after that it slows down. I am currently testing with half SPI since it cannot not send and 2 nibbles have to be sent separately. With no r/w it will not beat parallel. ILI9499 Having looked at the color/touch screen datasheet, it is one of the most complicated datasheets I have ever seen. ILI9488_Preliminary_DS_V090. <<--- google that. 339 pages and that is not including touch screen interfacing. Something on the backburner. SPI and DMA. 320 x 256 pixels * 24bit. 245,760 bytes for a full display. |
HTTPS://www. BangGo.COM/3Y2-ICH-ILI931-TFT-LCD-DISPLASE模块触摸屏-ARDUNIO-P918609HTML?RMDSDS =搜索14.76美元
以上来自于百度翻译 以下为原文 https://www.banggood.com/3_2-Inch-ILI9341-TFT-LCD-Display-Module-Touch-Panel-For-Arduino-p-918609.html?rmmds=search $14.76 |
如果你说的是:HTTP://www. MyCHIP.COM/DeavigoToSs/OpjtDebug?ASPX?PARTNO = D240312和HTTP://www. McCHIP.COM/DealthOrthsStudio/StudioDeLIL.ASPX?PATNONO=AC164127—4,在当前MLA中仍然存在箱外支持:www. McCHIP.COM/MLA
以上来自于百度翻译 以下为原文 if you are talking about: http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=DM240312 and http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=AC164127-4 There are still out of the box support in current MLA: www.microchip.com/mla |
奇怪的是,你说Microchip向你发送了不包含你所要求的代码,这是哪种渠道?如果这是通过我们的网上售票系统,你能帮我告诉我电话号码吗?谢谢。
以上来自于百度翻译 以下为原文 curious, you said microchip sent you code that doesn't contain what you were asking, which channel of support was this? If this is via our web ticket system, could you help tell me the case number? Thx. |
OP正在寻找购买模块的地方,而不是源代码。
以上来自于百度翻译 以下为原文 The OP is looking for somewhere to buy the modules, not source code. |
是的,我正在寻找一个3.2“TFT-LCD SD1289LCD兼容真正的3.2”开发显示在PUSB的第二个链接:HTTP://www. McCHIP.COM/DealthOrthsStudio/StudioDeLiels.ASPX?PATNONO=AC164127—4I发现微芯片有一个LCD图形触摸开发板,这是一个没有人提供的LCD!
以上来自于百度翻译 以下为原文 Yes, I am looking for a 3.2" tft lcd sd1289 lcd compatible with the Truly 3.2" development display found in Pu***'s second link: http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=AC164127-4 I find it incredible that Microchip has an lcd graphics touch development board using an lcd that NOBODY supplies! |
TrayYayBaycom,搜索“3.2 SSD1289.”
以上来自于百度翻译 以下为原文 Try ebay.com, search for "3.2 SSD1289". |
我有,但它们不是同一个接口。我有开发板的工作代码,包括控制VSYNC和HSYNC信号,以及在触摸发生时测量X和Y信号。易趣网显示器带有一个不带来这些信号的载波板(我必须把代码转换到所有SPI接口)。找到一个由Crystalfontz制作的显示器,但是它使用了一个不同的控制器(SITRONIX ST77 89VNOSSSD12898),所以我必须改变代码。我以前还没有做过图形设计,所以我真的很想坚持在开发板上工作的代码。
以上来自于百度翻译 以下为原文 I have but they aren't the same interface. I have working code for the development board which includes control of the vsync and hsync signals along with measuring the x and y signals when a touch occurs. The ebay displays come with a carrier board that does not bring those signals out (I'd have to change the code to all spi interface). I did find a display made by Crystalfontz but it uses a different controller (Sitronix ST7789V not ssd1289) so I'd have to change THAT code. I haven't done a graphics design before so I'd really like to stick with the code that works on the development board. |
我有一个.33页的数据表,不包括触摸部分。
以上来自于百度翻译 以下为原文 I've got this one. 339 page Datasheet and that is not including the touch part. ILI9488_Preliminary_DS_V090 |
只有小组成员才能发言,加入小组>>
5166 浏览 9 评论
2000 浏览 8 评论
1928 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3174 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2226 浏览 5 评论
733浏览 1评论
615浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
505浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
631浏览 0评论
528浏览 0评论
GMT+8, 2024-11-24 04:49 , Processed in 1.375689 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
