电子发烧友论坛|
我对LPS25H MEMS气压计芯片很感兴趣,但我很难搞清楚HCLGA-10L封装的尺寸。
以下是数据表中提到的内容: 我不能从他的垫子的尺寸解读。我相信e1 / 2可能会给我宽度,但我无法确定长度。也许那就是B应该是什么意思,但我没有看到它。 另外,我发现有一个http://www.st.com/st-web-ui/stat ... note/DM00064026.pdf 但找不到一个LPS25H。我意识到这是一个非常新的部分,但这会有所帮助 - 它提供了如何布置衬垫的一些指导。 有人可以更机械地倾向于为我解析这个吗? 谢谢。 #hclga-10L 以上来自于谷歌翻译 以下为原文 I am interested in the LPS25H MEMS barometer chip, but I am having a hard time figuring out the footprint of the HCLGA-10L package. Here is what is called out in the datasheet: I cannot decipher from his what the dimensions of the pads should be. I believe that e1/2 might give me the width, but I cannot determine the length. Maybe that's what B is supposed to mean, but I don't see it. Also, I found that there is a http://www.st.com/st-web-ui/stat ... note/DM00064026.pdf but cannot find one for the LPS25H. I realize it's a very new part, but this would help -- it provides some guidance on how the pads should be laid out. Can someone more mechanically inclined parse this for me? Thanks. #hclga-10l |
3个回答
作为参考,这里是LPS331AP的品质因数,它是一个可比较的部分(虽然分辨率更差)。
T1和T2给出了垫的尺寸,其余的可以很容易地推断出来。 我想我应该只使用LPS331AP ...... 以上来自于谷歌翻译 以下为原文 For reference, here is the figure of merit from the LPS331AP, which is a comparable part (though with worse resolution). T1 and T2 give the dimensions of the pads, and the rest can be inferred easily. I suppose I should just use the LPS331AP instead... |
获得对ST的支持比从血石中获取血液要困难得多。它们位于本数据表的第3版,但仍未处理此问题。
飞思卡尔生产了几款价格相近的好零件。 以上来自于谷歌翻译 以下为原文 Getting support for ST is much harder than getting blood out of a stone. They are at Rev 3 of this data sheet and still haven't dealt with this problem. Freescale make a couple of nice parts which are similar in price. |
你好,
事实上,我们将提供更多细节的图纸质量; 您正在寻找的焊盘尺寸为:0.30mm x 0.45mm(公差+/- 0.05 mm) 您可以在此地址的LPS331AP正下方找到LPS25H AN http://www.st.com/stonline/stappl/resourceSelector/app?page=fullResourceSelector&doctype=application_note&SubClassID=1316 谢谢你的提问 以上来自于谷歌翻译 以下为原文 Hello, Infact we are going to improve the quality of the drawing with more details; The pad dimension you are looking for are: 0.30mm x 0.45mm (+/- 0.05 mm tolerance) You can find the LPS25H AN just below the LPS331AP , at this address http://www.st.com/stonline/stappl/resourceSelector/app?page=fullResourceSelector&doctype=application_note&SubClassID=1316 Thank you for your questions |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:17 , Processed in 0.555096 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1797
