你好,
我希望通过我做的修改来检查我的足迹(除去我们不使用的GPIO的各种垫片)。我以前有过类似的修改,但现在更喜欢让你们验证。我知道这远不是理想的,但这只是为了让我们一直等到今年晚些时候我们能拿到QFN计划。所以问题是,这些垫移除会使它非常不稳定吗?(机械的和电的)。 谢谢大家 以上来自于百度翻译 以下为原文 Hello there, I was hoping to get my footprint reviewed with the modifications I made (removal of various pads of GPIO's we aren't using). I have had success before with similar modifications but prefer to have it verified by you guys now. I know it's far from ideal but this is just to get us by until we can get our hands on the QFN package later this year. So the question, do these pad removals make it extremely unstable? (Both mechanically and electrically). Thank you guys |
1个回答
你好,
我与我们的硬件工程师进行了检查,他们认为这些拆卸会使包装机械不稳定,如果选择汽车PCB组装,可能会导致非常差的焊接成品率。一些评论 1。尽可能多地填充球以提高稳定性。 2。确保没有准确的痕迹在被移除的球下面-因为它可能导致短裤,如果层绝缘了微量的珠子(甚至在制造过程中) 三。确保你已经填充了所有的供应/ GND球,并将它们连接到外部。由于供应不是内部短路,你将不得不将它们连接到外部。 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 Hello, I checked with our hardware engineers and they felt that these many removals will make the package mechanically unstable and might result very poor soldering yield if you opt for auto PCB assembly. Some comments - 1. Populate as many more balls as you can to increase the stability. 2. Make sure there are no traces exactly below the removed balls - As it may result in shorts, if the layer insulating the trace peals off (even during manufacturing) 3. Make sure you have populated all supply/GND balls and connected them externally. As supplies are not shorted internally and you will have to connect them externally. Regards, Meenakshi Sundaram R |
只有小组成员才能发言,加入小组>>
743个成员聚集在这个小组
加入小组2014 浏览 1 评论
1773 浏览 1 评论
3565 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1707 浏览 6 评论
1474 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
388浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
273浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
365浏览 2评论
307浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
506浏览 2评论
GMT+8, 2024-10-3 06:22 , Processed in 0.860351 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
