电子发烧友论坛|
问候
我正在使用LIS2MDL为教育市场构建磁场传感器。当测量的磁场超过最大允许值时,我注意到LIS2MDL返回不可预测的数据而不是0x7fff(32767)或0x8000(-32768)。 有没有办法可以检测磁场测量溢出,以便我们的可视化软件可以让用户知道测量数据无效? 谢谢 Scott Wild 以上来自于谷歌翻译 以下为原文 Greetings I am using the LIS2MDL to build a magnetic field sensor for the education market. When the magnetic field being measured exceeds the maximum allowed value, I notice that the LIS2MDL returns unpredictable data rather than 0x7fff (32767) or 0x8000 (-32768). Is there a way I can detect a magnetic field measurement overflow so that our visualization software can let the user know the measurement data is invalid? Thank you Scott Wild |
2个回答
嗨,
您可以检查INT_SOURCE_REG中的MROI位。如果发生测量范围溢出,该标志会发出警报。确保中断发生器有效(IEN位= 1)。通过读取INT_SOURCE_REG复位锁存的MROI位。 问候 马切伊 以上来自于谷歌翻译 以下为原文 Hi, You can check the MROI bit in INT_SOURCE_REG. This flag alerts if a measurement range overflow has occured. Make sure that the interrupt generator is active (IEN bit = 1). Latched MROI bit is reset by reading INT_SOURCE_REG. Greetings Maciej |
嗨,我对LIS2MDL和LIS3MDL都有相同的行为。
我的应用是检测磁铁的接近程度。在大约1厘米的范围内,措施出乎意料。 我已经用其他一些传感器进行了一些实验,但只有一个轴,行为与预期的一样:磁铁越近,测量值越高,直到饱和度保持饱和状态...... 我已经尝试过Maciej的命题,但这个过程来得太晚了,措施已经错了。 斯科特你是否设法得到正确的操作? 谢谢 彼得 以上来自于谷歌翻译 以下为原文 Hi, I have the same behaviour with LIS2MDL and also with a LIS3MDL. My application is to detect the proximity of a magnet. Under about 1cm the measures are unexpected. I have done some experiments with some other sensors but with only one axe and the behaviour is as expected : the closer the magnet, the higher the measurement until saturation, which stays saturation... I have tried the Maciej's proposition but this process comes too late, the measures are already false. Scott did you manage to get a correct operation ? Thanks Peter |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 14:32 , Processed in 1.536441 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1999
