当我测量透明物体的范围,如玻璃或丙烯酸,具有近背景时,传感器测量背景而不是物体。
我可以使用一些设置来处理这个问题吗?可能与串扰设置有关? 此致 赫里 #vl6180x 以上来自于谷歌翻译 以下为原文 When I measure range of a transparent object like glass or acrylic, with a near background, the sensor measure the background instead of the object. Is there some setting I can use to handle this? may be something to do with the crosstalk setting? Sincerely, Heri #vl6180x |
1个回答
你好Heri,
由于VL6180X器件使用聚焦激光束作为光源,因此可以通过透明玻璃或塑料轻松传输。塑料将允许一些光线反射回传感器,然而,与位于透明塑料背面的一块材料相比,这将是最小的。如果要查看塑料对信号返回的影响,请从塑料背面取下一块材料。没有这种材料的返回信号速率将是来自塑料的返回信号。要获得此返回信号速率,请读取RESULT__RANGE_RETURN_RATE,寄存器0x0066。 如果您想检测一块塑料远离VL6180X的距离,可以考虑使用不透明塑料,使光子反弹回传感器并报告距离。 谢谢, 科林 以上来自于谷歌翻译 以下为原文 Hello Heri, As the VL6180X device uses a focused laser beam for its light source, it will trasmit fairly easily through clear glass or plastic. The plastic will allow some light to bounce back into the sensor, however, this will be minimal compared to a piece of material located at the back of your clear plastic. If you want to see the effect of your plastic on the signal return, remove the piece of material from the back of the plastic. The return signal rate without this material will be the return signal from the plastic. To get this return signal rate, read RESULT__RANGE_RETURN_RATE, register 0x0066. If you want to detect how far a piece of plastic is away from the VL6180X, consider using opaque plastic that will allow the photons to bounce back into the sensor and report a distance. Thanks, Colin |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2733 浏览 1 评论
3241 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1810 浏览 1 评论
3650 浏览 6 评论
6038 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
443浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
274浏览 2评论
GMT+8, 2024-12-23 19:23 , Processed in 1.023950 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
