电子发烧友论坛|
我试图优化我的应用程序的闪存和RAM使用。我使用的是433W收音机。我注意到BRCMYPATCHAMAMBUF位于RAM部分。它严格地需要吗?我看到声明是const,但它仍然在我的应用程序中找到并加载到RAM中,全部40K。
它是BT堆栈正在进行操作所需的读/写区域吗?(像划痕部分) 值得注意的是,我包括在我的应用程序MaFixFix: GualALLO定义:= MaxAddiSrsStySyBySub主机 WiDeDeDCTA包含 定义了 以上来自于百度翻译 以下为原文 I am trying to size optimize my app for flash and RAM usage. I am using a 4343W radio. I noticed that brcm_patchram_buf is being located in the RAM section. Does it strictly need to be? I see that the declaration is const, but it still gets located & loaded into RAM in my app, all 40K of it. Is it a read/write area needed to ongoing operation of the BT stack? (like a scratch section) Notably, I am including in my app makefile: GLOBAL_DEFINES := MAC_ADDRESS_SET_BY_HOST WICED_DCT_INCLUDE_BT_CONFIG BT_CONFIG_APPLICATION_DEFINED |
2个回答
我猜你正在使用SDK-61.
你需要使用下面的补丁(见:有wiced_bluetooth_firmware_driver_for_bcm43438a1故意搬到RAM WICED 6.1) https://community.cypress.com/servlet/jiveservlet/download/152602-34556/map_parse_gcc.pl.zip 以上来自于百度翻译 以下为原文 I guess you are using sdk-6.1. You need to apply below patch (see Re: Has WICED_Bluetooth_Firmware_Driver_for_BCM43438A1 been deliberately moved to RAM in WICED 6.1 ) https://community.cypress.com/servlet/JiveServlet/download/152602-34556/map_parse_gcc.pl.zip |
uwueyvwew 发表于 2018-9-20 14:18 谢谢! 这也存在于SDK 6.2中。 我想我应该已经明白了,因为“const”关键字实际上不是我的芯片组。 现在,如果只有WICEDFS没有最低限度的文件化,我们可以把它放入Sflash中的文件系统中,并保存另一个40K的Flash… 以上来自于百度翻译 以下为原文 Thanks! This is also present in SDK 6.2 . I guess I should have figured this out, since the "const" keyword wasn't *actually* there for my chipset. Now if only WICEDFS wasn't so minimally documented, we could put that into the filesystem-in-sflash and save another 40K of flash ... |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7459 浏览 0 评论
2492 浏览 1 评论
2184 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2095 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7946浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6518浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
736浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8370浏览 2评论
/9
GMT+8, 2025-12-17 15:38 , Processed in 0.696670 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
575
