嗨,
我正在关注手册UM2084和UM2073以及iks01a2板上的所有东西都可以正常工作,*****负载每次都通过网络到达应用程序,但是当我重置并将iks01a2板添加到开发工具包时在终端窗口中获取PHY txtimeOut用于每次尝试的tx没有rx发生在我收到此错误时,非常有效的有效负载到达应用程序但没有其他人在发生此错误时执行此操作。在i-cube-lrwan软件中,我正在使用端节点演示,在hw_conf.h文件中,我取消注释了sensor_enable定义,在手册后面应该让它工作,我使用keil作为工具链进行编译和闪烁开发工具包。请帮助或如果有人知道更好的更明确的指南,请分享,因为搜索似乎没有提出任何答案。提前thx。 以上来自于谷歌翻译 以下为原文 Hi, I am following manuals UM2084 and UM2073 and with out the iks01a2 board everything thing works fine with the ***** payload reaching the application over the web every-time, but when i reset up and add the iks01a2 board to the dev kit i get PHY txTimeOut in the terminal window for every tried tx no rx happens when i get this error, also the very frist payload reaches the application but no others do when this error happens. In the i-cube-lrwan software i am using the end node demo and in the hw_conf.h file i do un-comment the sensor_enable define which following the manual should get it to work and i am using keil as the toolchain for compiling and flashing the dev kit. Please help or if anyone knows a better more definitive guide to follow please share as searches seems to bring up no answers. thx in advance. |
4个回答
我对p-nucleo-lrwan1没有任何经验,但arduino引脚上没有任何冲突。
以上来自于谷歌翻译 以下为原文 I don't have any experience with the p-nucleo-lrwan1 but isn't there any a conflict on the arduino pins. |
嗨,
大部分时间我一直在玩它,并且发现断开JP3实际上会使传输恢复工作,但似乎温度传感器不起作用,因为我在应用程序上得到-499。所以你已经说过有冲突并且删除了JP3,冲突就解决了。你是否认为还有另一种方法可以解决这个问题,以避免在arduino引脚上产生冲突。我对x-nucleo-board没有经验,所以希望你能够解决这个问题。 thx的帮助。 以上来自于谷歌翻译 以下为原文 Hi, i been playing around with it most of the day and have discovered that disconnecting JP3 will in fact bring the transmission back working, but it seems that the temp sensor does not work then as i get -499 on the application. so as you have stated there is conflict and with JP3 removed the conflict is resolved. Do you think that there is another way around this in order to get the temp working with out causing conflict on the arduino pins. i have no experience with the x-nucleo-boards so hopefully you might be able to get me around this. thx for the help. |
当您断开JP3时,您断开温度和湿度传感器HTS221的电源,因此传感器不工作。我检查了IKS01A2和LRWAN1的原理图,看来HTS221的DRDY中断与LRWAN1的DIO0冲突。
所以我会尝试保持跳线JP3但是断开所有跳线从JP6(默认情况下,HTS221 DRDY信号有一个跳线)。 以上来自于谷歌翻译 以下为原文 When you disconnect the JP3 you disconnect power supply for the temperature and humidity sensor HTS221, so the sensor doesn't work. I have checked the schematics of the IKS01A2 and the LRWAN1 and it seems the DRDY interrupt of the HTS221 is in conflict with DIO0 of the LRWAN1. So I would try to keep the jumper JP3 but disconnect all jumpers from JP6 (by default there is one jumper for the HTS221 DRDY signal). |
非常感谢这个解决方案,确实断开JP6上的跳线解决了问题所有工作正如预期现在感谢你的时间努力得到很好的赞赏。
以上来自于谷歌翻译 以下为原文 thanks very much for this solution, indeed disconnecting jumper on JP6 solved the problem all working as expected now thanks for your time effort well appreciated. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 01:12 , Processed in 0.909870 second(s), Total 81, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
399
