嗨,
unicleo不工作在FFT模式下(& sharpIKS01A2 + NUCLEO-F401RE与STM32CubeExpansion_MEMS-XT1_V4.2.0),其用户消息窗口显示''AST Protocol:CHK_CheckAndRemove Failed''。 FFT图未显示任何图形。 请帮忙 ! 提前致谢 !! VK Verma #x-nucleo-iks01a2#iks01a2 以上来自于谷歌翻译 以下为原文 Hi, unicleo not working in FFT mode with (&sharpIKS01A2+ NUCLEO-F401RE with STM32CubeExpansion_MEMS-XT1_V4.2.0) and its user message window is showing ''AST Protocol: CHK_CheckAndRemove Failed''. FFT plot is not showing any graph. Please help ! Thanks in Advance !! VK Verma #x-nucleo-iks01a2 #iks01a2 |
5个回答
我无法复制这个问题。
我看到你打开了Keil uVision程序,你修改了FFT_demo的例子吗? 你能尝试使用位于二进制目录中的已编译二进制文件吗? 以上来自于谷歌翻译 以下为原文 I'm not able to replicate the issue. I see you have Keil uVision program opened, did you modify the FFT_demo example? Can you please try to use already compiled binary located in binary directory? |
你好Miroslav,
您及时的回复帮助了我们很多! 我必须说你抓住了正确的点,当我用二进制编程时,它起作用了 但现在它没有使用Tera-Terminal软件,波特率为115200 bps; 8个数据位;没有平价; 1个停止位;自述文件中没有给出硬流量控制。 我会调查这个并在帖子中更新你。 再一次,非常感谢您的支持! 谢谢和最诚挚的问候, VK Verma 以上来自于谷歌翻译 以下为原文 Hi Miroslav, your timely response helped us a lot ! I must say that you catch the right point and when I programmed it with binary, it worked But now it is not working with Tera-Terminal software at baud rate 115200 bps; 8 data bits; No parity; 1 stop bit; no hard flow control given in the readme. I will look into this and update you in the post. Once again, Thank you very much for your support !! Thanks and Best Regards, VK Verma |
你好Miroslav,
根据建议,它的工作波特率为921600。然后我认为在ReadMe中错误地提到它 115200 bps。 谢谢你的立即回复! 请再给我一个支持(如果可能的话)....你能不能提出一些文件来帮助我们理解这个文件中给出的FFT库函数,以便它们可以在其他应用程序中修改和重用。 谢谢和最诚挚的问候, VK Verma 以上来自于谷歌翻译 以下为原文 Hi Miroslav, As per suggestion it is working in 921600 baud rate. Then i think it is wrongly mentioned in ReadMe for 115200 bps. Thanks for your immediate reply ! Please give me one more support (if possible).... can you kindly suggest some documents which will help us to understand FFT library functions given in this file, so that they can be modified and reused in other applications. Thanks and Best Regards, VK Verma |
你是对的,readme.txt文件中有一个错误,我们会修复它。
对于FFT功能,您可以检查 http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-dspdemo.html 或http://www.keil.com/pack/doc/CMSIS/DSP/html/index.html 。 以上来自于谷歌翻译 以下为原文 You are right, there is a mistake in the readme.txt file, we will fix it. For the FFT functions you can check http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-dspdemo.html or http://www.keil.com/pack/doc/CMSIS/DSP/html/index.html . |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 01:59 , Processed in 1.299908 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
435
