电子发烧友论坛|
文档似乎表明P40不需要gpumodeswitch。
但是,安装NVIDIA GRID VIB后,我看到以下内容(dmesg): 2017-11-07T00:15:17.689Z cpu15:69668)NVRM:加载NVIDIA UNIX x86_64内核模块384.73星期一8月21日15:16:25 PDT 2017 2017-11-07T00:15:17.689Z cpu15:69668) 2017-11-07T00:15:17.689Z cpu15:69668)设备:191:从91注册的驱动程序'nvidia' 2017-11-07T00:15:17.690Z cpu15:69668)Mod:4968:nvidia的初始化成功,模块ID为91。 2017-11-07T00:15:17.690Z cpu15:69668)nvidia加载成功。 2017-11-07T00:15:17.691Z cpu13:66219)IOMMU:2176:设备0000:3b:00.0放置在新域0x4304cc3e8af0中。 2017-11-07T00:15:17.691Z cpu13:66219)DMA:945:保护DMA引擎'NVIDIADmaEngine'。 将父PCI设备0000:3b:00.0放在IOMMU域0x4304cc3e8af0中。 2017-11-07T00:15:17.691Z cpu13:66219)DMA:646:DMA引擎'NVIDIADmaEngine'使用映射器'DMAIOMMU'创建。 2017-11-07T00:15:17.691Z cpu13:66219)NVRM:这是由系统映射到16 TB以上的64位BAR NVRM:BIOS或VMware ESXi内核。 分配此PCI I / O区域 NVRM:内核不支持您的NVIDIA设备。 NVRM:BAR1是32768M @ 0x3820 $ 这适用于vSphere 6.5 Enterprise Plus。 我无法安装gpumodeswitch VIB甚至试用它... 我错过了安装的一个步骤吗? 以上来自于谷歌翻译 以下为原文 The documentation seems to indicate that the P40 does not require a gpumodeswitch. However, after installing the NVIDIA GRID VIB, I see the following (dmesg): 2017-11-07T00:15:17.689Z cpu15:69668)NVRM: loading NVIDIA UNIX x86_64 Kernel Module 384.73 Mon Aug 21 15:16:25 PDT 2017 2017-11-07T00:15:17.689Z cpu15:69668) 2017-11-07T00:15:17.689Z cpu15:69668)Device: 191: Registered driver 'nvidia' from 91 2017-11-07T00:15:17.690Z cpu15:69668)Mod: 4968: Initialization of nvidia succeeded with module ID 91. 2017-11-07T00:15:17.690Z cpu15:69668)nvidia loaded successfully. 2017-11-07T00:15:17.691Z cpu13:66219)IOMMU: 2176: Device 0000:3b:00.0 placed in new domain 0x4304cc3e8af0. 2017-11-07T00:15:17.691Z cpu13:66219)DMA: 945: Protecting DMA engine 'NVIDIADmaEngine'. Putting parent PCI device 0000:3b:00.0 in IOMMU domain 0x4304cc3e8af0. 2017-11-07T00:15:17.691Z cpu13:66219)DMA: 646: DMA Engine 'NVIDIADmaEngine' created using mapper 'DMAIOMMU'. 2017-11-07T00:15:17.691Z cpu13:66219)NVRM: This is a 64-bit BAR mapped above 16 TB by the system NVRM: BIOS or the VMware ESXi kernel. This PCI I/O region assigned NVRM: to your NVIDIA device is not supported by the kernel. NVRM: BAR1 is 32768M @ 0x3820$ This is with vSphere 6.5 Enterprise Plus. I am unable to install the gpumodeswitch VIB to even try it out... Am I missing a step on the install? |
7个回答
检查BIOS设置。
您需要修改IOMMU设置以支持8GB的大BAR大小... 你用的是哪种硬件? 请与OEM核实。 以上来自于谷歌翻译 以下为原文 Check your BIOS settings. You need to modify the IOMMU settings to support the big BAR size of 8GB... Which hardware do you use? Check with the OEM. |
感谢您指点我正确的方向。
在Dell R740xd服务器上,我必须在BIOS - > Integrated Devices部分中执行以下操作: SR-IOV全局启用 - >启用(默认已禁用) 内存映射I / O库 - > 512 GB(默认值为56 TB) 我现在似乎正在路上,因为nvidia-smi现在正在返回值。 以上来自于谷歌翻译 以下为原文 Thank you for pointing me in the right direction. On a Dell R740xd server, I had to do the following in the BIOS -> Integrated Devices section: SR-IOV Global Enable -> Enabled (Default was Disabled) Memory Mapped I/O Base -> 512 GB (Default was 56 TB) I appear to be on my way now, as nvidia-smi is returning values now. |
完善。
感谢分享。 我相信其他客户会遇到与这个新硬件相同的问题。 我将尝试与DELL联系,以使其成为支持GPU的系统的默认配置。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Perfect. Thanks for sharing. I'm sure other customers will run into the same issue with this new hardware. I will try to get in contact with DELL to have this a default config for GPU enabled systems. Regards Simon |
谢谢你,戴尔R740和NVIDIA Telsa P40也遇到了同样的问题。
以上来自于谷歌翻译 以下为原文 Thank you for this I had exactly the same problem with a Dell R740 and NVIDIA Telsa P40. |
感谢你的分享。
我有同样的问题,并通过上述bios更改解决了它。 更改后: SR-IOV全局启用启用 内存映射I / O基础为512 GB 服务器识别GPU卡并且nvidia-smi命令正常工作。 但是......当尝试使用共享的pci设备启动虚拟机时,我收到以下错误: 无法为vgpu'grid_p40-2q'初始化插件'/usr/lib64/vmware/plugin/libnvidia-vgx.so' 有没有人遇到过这个问题? 以上来自于谷歌翻译 以下为原文 Thank you for sharing. I had the same problem and solved it with the above bios changes. After changing: SR-IOV Global Enable to Enabled Memory Mapped I/O Base to 512 GB The server recognizes the GPU card and the nvidia-smi command works fine. But... When trying to power on a vm with shared pci device, I get the following error: could not initialize plugin '/usr/lib64/vmware/plugin/libnvidia-vgx.so' for vgpu 'grid_p40-2q' Has anyone of you encountered this issue? |
是的...你是对的,现在就把它弄好了。
试... 谢谢 以上来自于谷歌翻译 以下为原文 Yeh... you're right, got it right now. Trying... Thank you |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3410 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3827 浏览 4 评论
/9
GMT+8, 2025-12-10 19:49 , Processed in 0.913372 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3961
