电子发烧友论坛|
我有安装了m6卡的b200-m4服务器。
但是,在使用Grid快速启动指南安装vib之后,nvidia-smi会返回错误。 有关原因的任何信息? 我看到这个思科服务器已通过网格认证: [root @ localhost:〜] nvidia-smi NVIDIA-SMI因为无法与NVIDIA驱动程序通信而失败。 确保已安装并运行最新的NVIDIA驱动程序。 [root @ localhost:〜] esxcli硬件平台搞定 平台信息 UUID:???? 产品名称:UCSB-B200-M4 供应商名称:Cisco Systems Inc. 序列号: ??? IPMI支持:true [root @ localhost:/ tmp] esxcli hardware pci list | grep -i Nvidia -A 20 -B 20 0000:81:00.0 地址:0000:81:00.0 段:0x0000 总线:0x81 插槽:0x00 功能:0x0 VMkernel名称: 供应商名称:nVidia Corporation 设备名称:3D控制器 已配置所有者:未知 当前所有者:VMkernel 供应商ID:0x10de 设备ID:0x13f3 SubVendor ID:0x10de 子设备ID:0x1143 器件类:0x0302 设备类名称:3D控制器 编程接口:0x00 版本ID:0xa1 中断线:0x0b IRQ:11 中断向量:0x35 PCI引脚:0x00 产生的总线:0x00 标志:0x0201 模块ID:-1 模块名称:无 底盘:0 [root @ localhost:〜] esxcli软件振动列表| grep -i nvidia NVIDIA-vGPU-VMware_ESXi_6.0_Host_Driver 367.64-1OEM.600.0.0.2494585 NVIDIA VMwareAccepted 2017-01-02 [根@本地〜] 以上来自于谷歌翻译 以下为原文 I have b200-m4 server with m6 card installed. However after installing the vib using the Grid quick startup guide, the nvidia-smi returns error. Any information regarding why? I see this Cisco server is certified with grid: [root@localhost:~] nvidia-smi NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running. [root@localhost:~] esxcli hardware platform get Platform Information UUID: ???? Product Name: UCSB-B200-M4 Vendor Name: Cisco Systems Inc Serial Number: ??? IPMI Supported: true [root@localhost:/tmp] esxcli hardware pci list | grep -i Nvidia -A 20 -B 20 0000:81:00.0 Address: 0000:81:00.0 Segment: 0x0000 Bus: 0x81 Slot: 0x00 Function: 0x0 VMkernel Name: Vendor Name: nVidia Corporation Device Name: Configured Owner: Unknown Current Owner: VMkernel Vendor ID: 0x10de Device ID: 0x13f3 SubVendor ID: 0x10de SubDevice ID: 0x1143 Device Class: 0x0302 Device Class Name: 3D controller Programming Interface: 0x00 Revision ID: 0xa1 Interrupt Line: 0x0b IRQ: 11 Interrupt Vector: 0x35 PCI Pin: 0x00 Spawned Bus: 0x00 Flags: 0x0201 Module ID: -1 Module Name: None Chassis: 0 [root@localhost:~] esxcli software vib list | grep -i nvidia NVIDIA-vGPU-VMware_ESXi_6.0_Host_Driver 367.64-1OEM.600.0.0.2494585 NVIDIA VMwareAccepted 2017-01-02 [root@localhost:~] |
7个回答
这是ESXi版本:
[root @ localhost:〜] esxcli系统版得到 产品:VMware ESXi 版本:6.0.0 构建:Releasebuild-2494585 更新:0 补丁:0 以上来自于谷歌翻译 以下为原文 Here is the ESXi version: [root@localhost:~] esxcli system version get Product: VMware ESXi Version: 6.0.0 Build: Releasebuild-2494585 Update: 0 Patch: 0 |
None
以上来自于谷歌翻译 以下为原文 You probably need to switch from "3D controller" to "VGA Controller" mode - see http://nvidia.custhelp.com/app/answers/detail/a_id/4164/~/running-the-gpumodeswitch-tool-on-grid-m60%2Fm6-cards-on-vmware-esxi-returns-an + study package "NVIDIA-gpumodeswitch-2016-04.zip" + "GRID gpumodeswitch User Guide.pdf" ... and blogs like https://virtuallyvisual.wordpress.com/2016/04/19/nvidia-m60-m6-problems-check-your-card-in-graphics-mode/ and |
谢谢,我跟着它,但现在得到这个错误。
我也从net ssh连接看到同样的错误,但也从hypervisor自己的控制台看到: [root @ localhost:〜] gpumodeswitch --gpumode graphics NVIDIA GPU模式切换实用程序版本1.23.0 版权所有(C)2015,NVIDIA Corporation。 版权所有。 将所有适配器的GPU模式更新为“图形”? 按'y'确认或'n'选择适配器或任何其他键以中止: ÿ 将所有符合条件的适配器的GPU模式更新为“图形” 错误:使用基于字符设备读取卡信息失败。 [根@本地〜] [根@本地〜] [根@本地〜] [root @ localhost:〜] gpumodeswitch --gpumode graphics 以上来自于谷歌翻译 以下为原文 Thanks, I followed it, however getting this error now. I also see this same error from net ssh connection but also from hypervisor's its own console: [root@localhost:~] gpumodeswitch --gpumode graphics NVIDIA GPU Mode Switch Utility Version 1.23.0 Copyright (C) 2015, NVIDIA Corporation. All Rights Reserved. Update GPU Mode of all adapters to "graphics"? Press 'y' to confirm or 'n' to choose adapters or any other key to abort: y Updating GPU Mode of all eligible adapters to "graphics" ERROR: Read card info failed by using character device based. [root@localhost:~] [root@localhost:~] [root@localhost:~] [root@localhost:~] gpumodeswitch --gpumode graphics |
1)您可以尝试通过控制台(CIMC)切换模式,其中包含可启动的gpumodeswitch.iso映像(所选模式在卡上是持久的)。
2)您可以尝试使用“gpumodeswitch --listgpumodes”检测错误和/或输出log“more /tmp/listgpumodes.txt”,如pdf中所述。 您可以尝试“esxcli hardware pci list”或“esxcfg-info -a”或搜索日志中的相关错误“/var/log/vmkernel.log”... 3)如果您支付了支持更新和维护协议(SUMS),您可以尝试联系/致电NVidia支持。 以上来自于谷歌翻译 以下为原文 1) You can try to switch mode over console (CIMC) with included linux bootable gpumodeswitch.iso image (selected mode is persistent on card). 2) You can try detect errors with "gpumodeswitch --listgpumodes" and/or output log "more /tmp/listgpumodes.txt" as described in pdf. You can try "esxcli hardware pci list" or "esxcfg-info -a" or search log for relevant errors "/var/log/vmkernel.log" ... 3) You can try contact/call NVidia support if you paid for Support Updates and Maintenance agreement (SUMS). |
我做了,它现在处于图形模式。
但是nvidia-smi仍然回归同样的废话。 我不在这里 以上来自于谷歌翻译 以下为原文 i did and it is now in what appears to be in graphics mode. But nvidia-smi still returning the same crap. I am out of here. |
None
以上来自于谷歌翻译 以下为原文 You can try more blogs (or directly Cisco for validated setup) - https://virtuallyvisual.wordpress.com/2016/06/20/new-cisco-validated-design-featuring-ucs-b200-m4-with-nvidia-grid-m6-vgpu-available-now/ - for example - ESXi 6.0 Update 1, upgrade your Cisco UCS system to a version of Cisco UCS Manager that supports this card, BIOS tweaking (card must be mapped under 4G address space for ESXi) ... |
作为M6用户,您有权通过许可证获得支持。
请向您购买许可证和支持的组织提出支持案例。 思科或NVIDIA酌情。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 As an M6 user you should be entitled to support via your licenses. Please do raise a support case with the organisation you bought the licenses and support from e.g. Cisco or NVIDIA as appropriate. Best wishes, Rachel |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-2 00:35 , Processed in 0.906675 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3052
