电子发烧友论坛|
嗨,
我正在尝试通过GPU直通到vm(2008 64bit r2)ESXI 6.0.3。 在GPU直通并安装NVidia驱动程序之后。 我已经禁用了VMWARE SVGA。 现在,在设备管理器中,它仅显示启用了VMWARE Svga禁用的Quadro M4000。 我的控制台视图和vnc工作正常。 但我的显示端口背面没有任何输出。 显示端口显示黑色。 为此,我做了以下事情: 我在ESXI上做了GPU直通。 然后安装了VM。 通过VM PCI卡。 然后在VM中安装驱动程序。 将屏幕连接到端口1并运行Nvidia控制面板。 从系统拓扑中的控制面板我导出了EDID。 然后加载连接端口的edid。 它向我展示了GUI中连接端口上的电视图标。 然后我将外部屏幕作为主显示屏。 禁用VMWARE SVGA。 在此之后我重新启动了VM。 我的VM控制台屏幕正常工作,VNC工作正常,在设备管理器中我可以看到VMWARE Svga在启用Nvidia卡时被禁用。 现在,如果我在显示器端口上放置一个屏幕,它会显示黑色。 这是正常的吗? GPU直通是否正确完成。 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to do a GPU passthrough to a vm (2008 64bit r2) ESXI 6.0.3. After the GPU passthrough and installing the NVidia drivers. I have disabled the VMWARE SVGA. Now in the device manager it shows only the Quadro M4000 enabled with the VMWARE Svga disable. My console view, and vnc is working fine. But I don't have any output on the back of the display ports. The display ports show me black. To do this I did the following: I did a GPU passthrough on the ESXI. THen installed the VM. passed VM the PCI card. Then installed the drivers in the VM. Connected a screen to port 1 and ran the Nvidia Control panel. From the control panel in the System Topology I exported the EDID. Then loaded the edid of the connected port. It showed me the TV icon on the connected port in the GUI. Then I made the External screen as my main display. Disabled the VMWARE SVGA. After this I restarted the VM. MY VM console screen is working, VNC is working fine and in the device manager I can see VMWARE Svga to be disabled with Nvidia card enabled. Now if I put a screen on the display ports it shows me black. Is this normal. Is the GPU passthrough done properly. |
2个回答
嗨,
我不确定你会实现什么目标。 您想为VM使用GPU Passthrough,但另外您想使用Quadro板的物理显示头? 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, I'm not sure what you're going to achieve. You want to use GPU Passthrough for a VM but in addition you want to use the physical display head of the Quadro board? Regards Simon |
我们希望实现GPU直通。
我在不同主机上的Windows 2012和Windows 2008上都进行了GPU直通。 它适用于Windows 2012但不适用于Windows 2008我们使用Nvidia-smi验证它。 我们在两个VM上使用驱动程序版本:22.21.13.8601。 该卡是Nvidia Quadro M4000。 请指教。 以上来自于谷歌翻译 以下为原文 We want to achieve a GPU passthrough. I have done a GPU passthrough on both Windows 2012 and Windows 2008 on different hosts. It works properly for Windows 2012 but doesn't work with Windows 2008 we verified it using Nvidia-smi. We are using driver version: 22.21.13.8601 on both VMs. The card is Nvidia Quadro M4000. Please advise. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 03:38 , Processed in 0.619516 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3109
