电子发烧友论坛|
嗨,
我有3个Dell R730,每个服务器配置2个NVIDIA GRID K2板。 我通过在我的一台ESXi服务器上激活直通模式,将1个GPU专用于VM。 在启动应用程序Image Generator(Genesis IG)时,我注意到我的GPU实际使用率为99%,这解释了一些不太好的性能,它接近常规PC上的GeForce 970GTX所提供的但还没有真正存在 。 为了解决性能问题,我决定在passthough模式下为这台机器添加另一个GPU,现在我已经安装了2个GRID GPUS并显示在我的VM上。 我的问题是,可以让2 GPUS在多GPU支持概念或SLI中协同工作吗? 现在,如果我启动相同的应用程序,我只能看到1个GPU工作,另一个是0%。 单个GPU可能足以运行IG,如果我不必浪费25%的GPU用于PCoIP会话单独进入我的Zero客户端。 谢谢 帕斯卡尔 以上来自于谷歌翻译 以下为原文 Hi, I have 3 x Dell R730s configured with 2 x NVIDIA GRID K2 boards in each servers. I have dedicated 1 GPU to a VM by activating the passthrough mode on one of my ESXi server. When launching an application Image Generator (Genesis IG), I have noticed that my GPU was actually being used at 99% which explains some not so good performance, it is close to what the GeForce 970GTX on a regular pc provides but not really there yet. In order to address the performance issue I have decided to add another GPU to this machine in passthough mode and I have now 2 GRID GPUS installed and showing up on my VM. My question is it possible to have the 2 GPUS working together in a multi-gpu support concept or SLI? Right now if I launch the same application I can only see 1 GPU working and the other one is at 0%. A single GPU would probably be enough to run the IG if I didnt have to waste 25% on the GPU for the PCoIP session alone going to my Zero client. Thanks Pascal |
4个回答
这真的很不幸。
感谢你的及时回复。 帕斯卡尔 以上来自于谷歌翻译 以下为原文 That is really unfortunate. Thanks for your prompt reply. Pascal |
与K2相比,GRID 2.0 M60板的性能差异是什么?
以上来自于谷歌翻译 以下为原文 what is the performance difference of a GRID 2.0 M60 board compared to the K2s ? |
取决于1.4x和2x之间的工作负载
它还有两倍的GPU RAM。 以上来自于谷歌翻译 以下为原文 Depending on the workload between 1.4x and 2x It also has double the amount of GPU RAM. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 06:15 , Processed in 0.593520 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3501
