嗨,
我在ESX 6中使用GRID K2。 Atm有像GPU0和GPU1之间的负载平衡。 如果我在主机上打开2 K240q,则第一个VM被分配给GPU0,即第二个GPU1。 我无法启动此主机上的任何k220q vm。 我想实现GP20上的k240q上电。 我该如何配置? 任何帮助,将不胜感激 马尔科 以上来自于谷歌翻译 以下为原文 Hi, I´m using GRID K2 in ESX 6. Atm there is sth like loadbalancing between GPU0 and GPU1. If I power on 2 K240q on a host the first VM is allocated to GPU0, the second GPU1. I cant power on any k220q vm on this host. I want to achieve that both k240q power on at GPO0. How do I configure this? Any help would be appreciated Marco |
5个回答
在ESX主机上,将“vGPU.consolidation = true”添加到文件/ etc / vmware / config
然后在移动到下一个GPU之前先“填充”每个GPU,而不是在可用GPU上传播负载的默认值。 使用vSphere,您目前无法指定在哪个物理GPU上运行哪些配置文件,尽管这是VMware的调查范围。 以上来自于谷歌翻译 以下为原文 On ESX host, add "vGPU.consolidation = true" to file /etc/vmware/config That then "fills" each GPU first before moving to the next GPU, instead of the default which spreads load across the available GPU's. With vSphere you cannot currently specify which profiles run on which physical GPU's, though it is an area of investigation for VMware. |
正如JAson所说,我们为虚拟化供应商提供了实现分配的API,但实施和控制它的是VMware / Citrix,因此针对该行为的功能请求/错误应该由Citrix / VMware提供。
我知道vSPhere的一个警告(已知问题) - 我不确定他们是否已经解决了可能值得阅读您正在使用的版本的驱动程序发行说明并检查您是否看到它:http:// nvidia.custhelp.com/app/answers/detail/a_id/4129/kw/vmware%20known%20issues(ctrl-f for“allocation”) - 如果你确实看到它使用VMware记录了一张票,那么他们就会发现修复。 也许值得在VMware论坛上评论您的需求(有一个特定的NVIDIA),因此您的需求会突出显示。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 As JAson says we provide the virtualisation vendors the APIs to implement allocation but it is VMware/Citrix who implement and control it so feature requests/bugs against that behaviour should got to Citrix/VMware. I am aware of one caveat (known issue) with vSPhere - that I'm not sure has been resolved by them it might be worth reading the driver release notes for the version you are using and checking if you see it: http://nvidia.custhelp.com/app/answers/detail/a_id/4129/kw/vmware%20known%20issues (ctrl-f for "allocation") - if you do see it log a ticket with VMware so they issue with a fix. It might also be worth commenting on your needs on the VMware forums (there's an NVIDIA specific one) so your need is highlighted with them. Best wishes, Rachel |
谢谢 - 像魅力一样!
有没有可以找到这样的信息的地方? 马尔科 以上来自于谷歌翻译 以下为原文 Thank you - works like a charm! Is there a place where I can look for informations like this? Marco |
嗨马可,
很高兴听到Jason把你排除在外:-D 我原以为它应该在VMware部署指南中:http://www.vmware.com/content/dam/digitalmarketing/vmware/en/pdf/products/horizon/grid-vgpu-deployment-guide.pdf 我要提出一张票,看看我们是否可以自己更好地记录(尽管它是一个虚拟机管理程序功能,我们尝试只提供指向支持/维护功能的组织的链接)... VMware会在 有用的部分:https://pubs.vmware.com/horizon-7-view/index.jsp?topic =%2Fcom.vmware.horizon-view.desktops.doc%2FGUID-CECF1A1B-E7FF-4170-A4DB-0F875BB15F0A html的 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 Hi Marco, Glad to hear Jason sorted you out :-D I'd have thought it should be in the VMware deployment guide: http://www.vmware.com/content/dam/digitalmarketing/vmware/en/pdf/products/horizon/grid-vgpu-deployment-guide.pdf I'm going to raise a ticket to see if we can get this better documented ourselves (although it is a hypervisor feature and we try to just provide links to the organisation that supports/maintains features)... VMware do document it in a useful section here: https://pubs.vmware.com/horizon-7-view/index.jsp?topic=%2Fcom.vmware.horizon-view.desktops.doc%2FGUID-CECF1A1B-E7FF-4170-A4DB-0F875BB15F0A.html Best wishes, Rachel |
它已在我们的驱动程序发行材料和VMware部署指南中记录。
http://us.download.nvidia.com/Windows/Quadro_Certified/GRID/362.56/ESXi-6.0/361.45.09-362.56-nvidia-grid-vgpu-user-guide.pdf 第23页的第2.2.9节解释了这一点。 以上来自于谷歌翻译 以下为原文 It's already documented in our driver release materials and in the VMware deployment guides. http://us.download.nvidia.com/Windows/Quadro_Certified/GRID/362.56/ESXi-6.0/361.45.09-362.56-nvidia-grid-vgpu-user-guide.pdf Section 2.2.9 on Page 23 explains it. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3125 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3531 浏览 4 评论
GMT+8, 2024-12-22 19:08 , Processed in 0.663189 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
